Ignition coil bad ?
  • JRunk31
  • JRunk31's Avatar Topic Author
Ignition coil bad ? was created by JRunk31
I have a 1971 CT1 that I have been trying to get lights working on. The LED 6V headlight and LED strip light with signals and even brake work (but signals won’t flash yes I used two prong LED flasher relay….).
The gauge lights also work and are LED. I found the two open red wires at the tail light loom and added a 10a fuse in there which allowed my tail lights to function (not sure why it was removed).
So, now; the bike ran before I started wiring lights. It ran great but a little rich so I dropped it from a 150 main to a 130. TBD on plug color. I tested the ignition coil and got primary of 5.3 ohms (should be 4.9) and secondary of 14.5-19k ohms (should be 11k).
I attached a pic of the 6V battery hooked up to the coil and you can see the spark but it isn’t blue. I don’t see any spark when kicking it however. Would you agree it needs replaced? Any other ideas ?I changed nothing on ignition but I did replace the rectifier, but that shouldn’t change anything???!!! Right?
17 Oct 2022 12:36 #1
Replied by RT325 on topic Ignition coil bad ?
Just flicking a battery across your single wire AC coil will flash at the plug so coil is likely ok. I'd start at the points, give a scratch if you think they're not contacting. Could hotwire it from the black direct to the coil to eliminate anything in the loom & ign switch. Wouldn't worry about discrepancies in your coil reading as plug cap adds 5k. Other than that i'm lost at the moment. See what the knowledgeable say.
The following user(s) Liked this Post: JRunk31
17 Oct 2022 13:54 #2
