voltage regulator
  • tvrc18
  • tvrc18's Avatar Topic Author
voltage regulator was created by tvrc18
What are you using for a voltage regulator on the early 250 models? The one Yamaha recommends in the service bulletin are way expensive, $175. You can buy a bunch of bulbs for that much. I bought a universal type but it is a little big to fit in the headlight shell. it is about 3 inches long.
21 Aug 2021 21:55 #1
Replied by RT325 on topic voltage regulator
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=124602494995&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by Gr8uncleal on topic voltage regulator
I copied Mauser and used one of the horn mount bolts on my RT2 and DT3. I did have to fit an extension to the wire, so that it reached the connections in the headlight shell.
22 Aug 2021 00:09 #3
  • tvrc18
Replied by tvrc18 on topic voltage regulator
That is the one I bought. Does it work well? Did you have to make a bracket to mount to the horn and did you connect it to the blue headlight wires?
22 Aug 2021 06:40 #4
Replied by Sneezles61 on topic voltage regulator
That looks like the one I mounted yesterday..From Brain Tarp.. I bolted to the bottom, outside of the headlight bucket... The yellow wire was positioned so it was located right at opening for wires... I did stand it off so as not to touch the gizmo to the bucket... You really can't see it..
Sneezles61
22 Aug 2021 06:52 #5
Photos of mine attached in this order - DT3, RT2 and DT360A.
As you can see, the only one that I made a bracket for was the DT360A (which I might bend a little, just so that it aligns with the forks).
I'll need to check that the regulators are getting an earth from the frame. If they aren't, I'll make some new earth wires up.
Extra length of wire attached to the single yellow on the voltage regulator, and this attached to the blue in the headlight bucket.
As it happens, to save splicing the blues, I used some spare three port female connectors, with a very short link between the original double female and the triple (see last photo).
Last edit: 22 Aug 2021 07:57 by Gr8uncleal.
22 Aug 2021 07:54 #6
Replied by MarkT on topic voltage regulator
I keep my eyes out for used original Yamaha regulators on ebay.  I've never paid over $20 shipped and, knock wood, never received a bad one.  Early 80's models got much smaller but work just as good.
The main reason I buy used Yamaha is many new aftermarket look a likes simply don't work. I had a new one not work years ago and then found out DEET had done extensive research and testing and had not found any of the aftermarket look a like regulators to work like the Yamaha one does.  He posted a video here someplace.
Not to say every one of the aftermarket units have been tested and all don't work but many have been and none of the ones tested were found to work.
DEET has found a scooter regulator... made in Italy I think... that can be had new for a reasonable price...  three wire hookup...  might even be better than the Yamaha unit.  That's what I would buy if I wanted to go new.  DEET has them for sale or used to sell them.
P.S.  Original headlights are not cheap...  if you can find one.
Last edit: 22 Aug 2021 08:19 by MarkT.
22 Aug 2021 08:15 #7
Replied by dailyrider on topic voltage regulator
 This is where I mounted mine.....minor modification (enlarging) of one bolt hole.
22 Aug 2021 18:47 #8
Theres mine...under the bucket
Sneezles61
23 Aug 2021 05:46 #9
Replied by Pete-RT1 on topic voltage regulator
Here's the one on my CT1-C, not sure if the larger ones will fit in this position.
Yamaha CT3 (in bits)
23 Aug 2021 12:00 #10
