‘68 tank refurb guidance
- type one
‘68 tank refurb guidance was created by type one
Hi All
so I bought this tank from a guy in Canada in early March …. It’s just arrived and is all good…
I know the tank badge indents have been bondo’d but I’m hoping to over come that and fingers crossed the badge fastener strips are still there …
I’ve seen a few suggestions for
bondo removal and am leaning towards a plumbers torch to soften up the bondo…. Other successful methods welcome ….
it will eventually get a professional paint job so I’m keen to perfect the right pin strip shape … again all guidance and knowledge welcome please …
cheers
T1
Hi All
cheers
T1
cheers
T1
Hi All
cheers
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
23 Jun 2021 02:45
- Schu
Replied by Schu on topic ‘68 tank refurb guidance
See my thread on the same issue with badge mounts filled in.
yamaha-enduros.com/index.php/forums/mini...there-s-a-better-way
The following user(s) Liked this Post: type one
23 Jun 2021 09:17
- nhsteve
Replied by nhsteve on topic ‘68 tank refurb guidance
Had the same issue with one a '68 tank I was hoping to use. The recesses had been filled in with Bondo (or similar). I used a small propane torch and after just a couple of minutes the filler was easily removed with a putty knife.
Unfortunately in my case the previous owner had cut just the drilled and taped holes for the screws, leaving with some fabrication still to be done (
29 Sep 2021 07:40
- JGersh
Replied by JGersh on topic ‘68 tank refurb guidance
Successfully removed bondo with a cheap Harbor Freight heat gun…
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
- Rick C.
Replied by Rick C. on topic ‘68 tank refurb guidance
Paint stripper softens it up too. It's a little slower than a wire brush, but works!
29 Sep 2021 11:43
- Dirtboy
Replied by Dirtboy on topic ‘68 tank refurb guidance
I'm keen to see how you progress with this, especially the paint match and application.
I have 2x 68' tanks in need of restoration and highly recommend plumbers torch to remove the bondo which I used the second time around after slightly bending the tabs using a wire brush and chisel at the first attempt.
29 Sep 2021 13:54
