any idea what item #34 is on this DT1E?
  • msavitt
  • msavitt's Avatar Topic Author
09 Mar 2021 09:13 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic any idea what item #34 is on this DT1E?
It's a piece of foam.
I raised a similar query a while ago relating to my RT2. Someone made the very valid point that perhaps it wasn't a good idea to have a moisture absorbing material right next to metal!
09 Mar 2021 09:35 #2
  • msavitt
Replied by msavitt on topic any idea what item #34 is on this DT1E?
odd touch
perhaps to deaden the tank ringing when low on gas?
I will pass on this since my wife tells me I am deaf
09 Mar 2021 09:46 #3
Replied by DEET on topic any idea what item #34 is on this DT1E?
It is a cushion for the tank.
I recommend it....(just my opinion)
The following user(s) Liked this Post: Badger52, nhsteve
09 Mar 2021 10:01 #4
Replied by Pedalcrazy on topic any idea what item #34 is on this DT1E?
Yamaha calls it a seal.  I've found on my bikes that still have it, it wraps around the bar and covers the connections coming from the magneto to where they plug into the harness.  I guess it is to keep water out of those connections?  I've bought 1" foam and cut it to the correct size and put on with a wrap of black tape.  That's how I've found them attached anyway.
09 Mar 2021 10:30 #5
  • msavitt
Thanks all
One more question on this 1971 DT1E
The left handle has a L-R switch....did this model come with turn signals which are not on the bike?
10 Mar 2021 13:54 #6
Replied by JGersh on topic any idea what item #34 is on this DT1E?
Per Enduronut foam size is 6.75" x 7.5" x 1 3/16"
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
10 Mar 2021 14:13 #7
Replied by Enduronut on topic any idea what item #34 is on this DT1E?
The following user(s) Liked this Post: Devin, RTD2
Last edit: 10 Mar 2021 14:27 by Enduronut.
10 Mar 2021 14:20 #8
  • msavitt
thanks and thanks!
i will make my own foam and my theory is that the crunched coil resulting in no lights and therefore their removal....I am going to have some work to do here!
10 Mar 2021 15:08 #9
Started tearing down my '68 DT1 and found another piece of foam in the headlight bucket....
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
10 Mar 2021 16:20 #10
