RT1 Help required
Replied by HouseofEnduro on topic RT1 Help required
That bike sounds great to me, none of mine run significantly different than what I hear there; I experience the surging frequently as well especially coasting downhill with throttle closed. My bigger concern is that you keep riding and passing oncoming cars ON THE WRONG SIDE OF THE ROAD!
The following user(s) Liked this Post: MarkT, Swoop56, Pete-RT1
17 Oct 2020 15:02 #11
  • Pete-RT1
  • Pete-RT1's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Replied by Pete-RT1 on topic RT1 Help required
No, you guys are on the wrong side which is the right side, the left side is the right side which is our side, or to put it more simply, left is right :woohoo:
Yamaha CT3 (in bits)
The following user(s) Liked this Post: Swoop56, HouseofEnduro
17 Oct 2020 17:02 #12
Replied by RT325 on topic RT1 Help required
Yes but that's a lean surge not a rich surge slowing down like these bikes are known for. That's the danger with lean, seizing. Rich you'll come to no harm--just annoying.
17 Oct 2020 17:07 #13
  • Pete-RT1
  • Platinum Member
  • Platinum Member
Update, definitely improved.
I did the following one at a time and tested after each mod.
I started with raising the needle one clip and although it was better off throttle it didn't run as nice when on throttle.
I left the needle in the new position and adjusted the air screw in half a turn and the surging was acceptable and what I imagine is normal.
Put the needle into the original position and it runs as good as yesterday when on throttle and the surging is acceptable.
It seems that the pilot circuit was running too lean.
I will endeavor to get her running as sweet as possible.
Thanks for the help guys, it's always appreciated.
The following user(s) Liked this Post: MarkT, HouseofEnduro
18 Oct 2020 07:12 #14
