CT-1 Clutch issues.
- PDXtyist
- Content Contributor
CT-1 Clutch issues. was created by PDXtyist
As our CT project is coming along we have an issue perhaps with clutch. Bike has new top end, new points and seals. Carb is tuned.
As we ride bike, acceleration is at first ok then the bike looses power and revs a bit with little or no power to the rear wheel no matter the gear we are in. We have a really strong feeling it’s the clutch slipping and not a carb issue.
Before we go digging into the clutch we need to be sure it is in fact the clutch.
-we tried to adjust the clutch via the Lock Nut and Adjust Screw. Even though we tightened the lock nut, the adjusting screw still spins freely and never locks. Any pointers on this? Will this, if properly adjusted,
prevent clutch slipping? Maybe clutch is being partially engaged somehow.
-besides new fiber plates, what other items should we think of replacing in clutch pack area?
-anything else we may be overlooking?
Thanks.
Thanks.
04 Sep 2020 17:57
Replied by RT325 on topic CT-1 Clutch issues.
Need a little more info please if possible, or a video. Clutch slip will have it revving up but not speeding up in a severe case. On the face of it--it sounds like the exhaust is blocked, which in a bad case will majorly restrict the power & the ability to rev.
04 Sep 2020 18:10
Replied by MarkT on topic CT-1 Clutch issues.
Is that a picture of what you are adjusting? If so, it's the neutral switch.
Adjustment is under the "bump" on the outer ignition cover.
The following user(s) Liked this Post: PDXtyist, HouseofEnduro
04 Sep 2020 18:12
- PDXtyist
Replied by PDXtyist on topic CT-1 Clutch issues.
Crud. I ought to have known. Thanks. Any idea on how it adjusts?
04 Sep 2020 18:38
- PDXtyist
Exhaust is clean. Wonder if it could be oil we are using??
04 Sep 2020 18:39
- darinm
Replied by darinm on topic CT-1 Clutch issues.
When you pull the LH side cover it's pretty obvious how it adjusts. The less the push rod is pushed in, the less it releases the clutch, aka the more engaged it is. If you do clutch plates, measure the springs with a caliper while you are at it. If original they may be compressed out of spec making it slip.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
And make sure new disks are correct thickness. Later models used the same size but thinner... IIRC yours uses 4mm thick disks and later ones are 3mm thick.
The following user(s) Liked this Post: PDXtyist, darinm
04 Sep 2020 22:39
Yep, reading with both eye open now it does sound more like clutch slip. Make sure the cable & operating mechanism are free to move so there's total release of the clutch as doesn't take much of a tight cable & moving bits to aid slipping.
05 Sep 2020 00:28
- PDXtyist
Thank you fellows.
How does one adjust the Neutral Stopper?
And what oil do you recommend? We’ve had good luck with Motul on other bikes.
05 Sep 2020 08:33
"Neutral stopper" is the large bolt at angle behind the neutral switch. There's a spring and ball bearing under bolt. Ball locks into dent in shift drum when in neutral. No real "adjustment"
Manuals in Tech Library will show how to adjust clutch and shift linkage... shift linkage doesn't routinely need to be adjusted, clutch does. Can't hurt to check shift linkage if you have cover off to work on clutch.
05 Sep 2020 09:22
