steering lock key
  • randolph
  • randolph's Avatar Topic Author
steering lock key was created by randolph
i have a 1971 yamaha 360 enduro rt1. i cant read the middle digit on the steering lock. its worn off. any suggestions on how to find that number anywhere else or where i can buy key blanks? the first digit is 3 the last is 7. just missing the middle number!
24 Jul 2020 12:00 #1
Replied by mdscott on topic steering lock key
Should be the same as the ignition switch.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
24 Jul 2020 12:45 #2
  • randolph
Replied by randolph on topic steering lock key
ah but it's snot. ignition 4 digit steerin 3 digit.
24 Jul 2020 13:52 #3
Replied by DEET on topic steering lock key
I have complete locks.
24 Jul 2020 14:52 #4
Replied by Pedalcrazy on topic steering lock key
Curious about your bike...my 71 RT1 360 doesn't have a steering lock. My 73 RT3 360 does have a steering lock. On the U.S. Bikes the steering lock doesn't show up in parts lists until 73. You may want to look at your bike's serial number and confirm for sure what you have. Titles can be wrong...serial numbers should tell for sure. In case you need other parts for your bike you'll want to know for sure what you have. Some parts are different between the 71 and 72/73.
Last edit: 24 Jul 2020 16:18 by Pedalcrazy.
24 Jul 2020 16:17 #5
Replied by johninga on topic steering lock key
If I remember correctly, the AT2, CT2, DT2 and DT3 do not have steering locks. Not sure about the LT2. Steering locks started in 1973.
25 Jul 2020 19:14 #6
  • randolph
Thanks - just checked my VIN's which are matching engine and frame the VIN falls right in the middle of the 71 VIN production, according to this website. The VIN is RT1-15999.
27 Jul 2020 13:05 #7
Replied by Yamrt3 on topic steering lock key
I'd like to chime in here. I have an RT# with the steering lock but no key. How would I get a properly cut key to fit? Thanks.
27 Jul 2020 13:44 #8
  • randolph
3 digit code on face of lock cyl. start there. mine had the center number destroyed so im buying a cyl assy from Deet
27 Jul 2020 14:24 #9
Thanks. So when I have the 3 digit number off of the lock, I then have to look on ebay for a key with that number on?
27 Jul 2020 15:38 #10
