JT1 shifting issues
- Schu
JT1 shifting issues was created by Schu
One of my JTs has shifting issues where the trans simply doesn’t do what you want it to do. You can sometimes find a gear, and you can sometimes get it back into neutral but it is simply a mess. So I decided to split the cases to try and sort this out.
I have a spare JT engine with the top end froze up solid so I started by splitting that one open first since I have never done this before. Trans looked OK on that froze up engine. Then I split the cases on the engine that I am trying to fix. I think I have found the issue, but I would like to confirm it and also determine why it occurred, unless this simply happens from long term use.
The link below shows some photos from both engines for comparison purposes. Hopefully the images come up in proper sequence to my descriptions below….
imgur.com/a/eI7Yhk2
The first image shows the shift drum circled in red.
The next image shows a stopper pin on the lower portion of the shift drum.
The next image shows how the stopper pin radially comes in contact with a boss on the side case.
The next image shows the boss with the shift drum removed.
The next image shows the stopper pin having rotated too far due to a damaged boss on the side case.
The last image shows the chewed up boss with the shift drum removed.
So would this damaged stopper boss cause my shifting issues?
Is this normal long term wear, or do I have other issues to sort out?
I see no other obvious issues with the trans parts.
Any help or advice would be greatly appreciated!
imgur.com/a/eI7Yhk2
- pabdt
Replied by pabdt on topic JT1 shifting issues
First, I've never worked on a JT1. : ) ...but since this is the internet...
I'm wondering if you have both axial and radial adjustment concerns. I usually take the shifter arms in a drill and polish the contact points where it meets the case w/alum oxide red, then VERY fine emery cloth to a polish also.
* Is it possible the shift drum is being "pulled/pushed" laterally by the alignment of the shifter arm? This ~may explain the movement further to the R side of the case and away from the stop. Also, shifter arm maximum axial movement. It may be able to move too far R/L. Shim necessary?
* Is the shifter adjustment correct and appear centered? Here is a video explain. Video of Shifter Arm Adjustment
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1973 Yamaha DT3 250
1974 Yamaha DT125A
- Schu
Replied by Schu on topic JT1 shifting issues
UPDATE
I may have discovered the root cause of the damaged boss on the side case. I have a different shift drum on the one with the damaged boss. That particular shift drum is a hollow shaft and the stopper pin is press fit but it extends into the hollow shaft. That particular stopper pin has considerably less protrusion than the one on my spare engine. Like it only protrudes half as much.
The shift drum on my spare engine is a solid shaft with the stopper pin pressed into a blind hole so it can’t be forced any deeper and ensures that the pin keeps the proper amount of protrusion. The solid shaft also has an additional window machined into it and I assume that was to reduce the mass of changing it to a solid shaft. So maybe I just discovered the root cause being that the stopper pin had worked its way deeper into the drum and minimized the amount of extension thus allowing it to chew away at the boss and ultimately allowing it to rotate too far. I’m still interested in your thoughts/opinions.
imgur.com/a/WmzHsMe
imgur.com/a/WmzHsMe
16 Dec 2025 12:15
Replied by MarkT on topic JT1 shifting issues
My guess is "crash damage" or someone stomping on the shift lever moved the pin and started the problem?
Since I think I remember the JT had a "4 up" shift pattern, this could definitely make it hard to find neutral. But once you got it in first, I would think it would shift okay up to second and third and then possibly have an issue with fourth?
16 Dec 2025 12:55
- Schu
Thank you PABDT for the How To link on shifter adjustment. Holy Moly there are a ton of great videos by Dale Sweger. I think I recall someone else mentioning his videos a while back, but I didn’t dig into it until just now. I’m retiring on the 23rd and will have more time on my hands. So maybe I’ll get an online education from Dale University!
16 Dec 2025 13:36
- Schu
Thanks Mark. I’m guessing it was due to Stomping the shifter. The GT80 is the one that has a “4 up” shift pattern. The JT has a “4 down” shift pattern.
So now it looks like I will have to use the shift drum and side case from my spare engine when I put this back together. Are side cases matched sets? Should I use both side cases from the spare engine to be safe?
16 Dec 2025 13:55
At one time I would have said you're probably okay to mix cases. Then I had an issue with a CT1 and the replacement case half didn't mate too well. There was a significant mismatch on the cylinder base gasket surface, one side was about 0.020" higher than the other. I didn't expect this and didn't notice until after I assembled the bottom end with new seals and Yamabond.
So I'd recommend a "dry assembly" and compare closely or used a matched set. (The only reason I'd mix halves if I had a good complete spare matched set is if I could keep the original VIN stamping)
16 Dec 2025 16:45
- Schu
I will use the matching set because VIN numbers are not a concern on this little rider. lol
Time to order bearings, gaskets, seals, etc…..
16 Dec 2025 16:55
- Sneezles61
Replied by Sneezles61 on topic JT1 shifting issues
Certainly has a great crackle to it!
16 Dec 2025 18:24
- ZTatZAU
Replied by ZTatZAU on topic JT1 shifting issues
Schu! said, "Holy Moly there are a ton of great videos by Dale Sweger. "
I have to agree! I've been following Dales 7 or 8 part video series on rebuilding an 80cc GT1. His camera work and thorough explanations are second to none. Highly recommended!
He works on a variety of 2-strokers and I've learned a lot about my GTMX from watching his videos. His GT1 "Lower End Assembly" video talks at length about case damage in the area of the shift drum and adjusting the shifter... though from your pictures on imgur, I see the bottom lug and case design are different than the GT1's but you may still find it helpful.
And while I haven't a clue about your DT, Dale replaced one case side on the GT1 which was individually (L&R) available as replacement parts. His replacement Right Side Case worked out fine on the GT1.
ZT
ZT
1971 K1 CB750, 1973 XLH1000, 1974 GTMXA, 1989 GL1500, 2008 FXDWG
13 Jan 2026 12:40
