12 volt battery
  • dchallenger
  • dchallenger's Avatar Topic Author
12 volt battery was created by dchallenger
anyone know what 12 volt battery fits in a 76 dt 400.thanks....
31 Dec 2018 20:33 #1
Replied by TerryM on topic 12 volt battery
The 76 DT400C was a six volt bike. Unless you've converted it to twelve volts by replacing bulbs, regulator, etc., a 12 volt battery would probably blow your bulbs.
01 Jan 2019 11:01 #2
  • dchallenger
Replied by dchallenger on topic 12 volt battery
yes did rex 12 volt.looks like they don't ship batterys to the u.s .I think I have located one...
01 Jan 2019 16:57 #3
  • AirborneSilva
  • AirborneSilva's Avatar
  • Online
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic 12 volt battery
I'm contemplating doing this to my 76 DT400C, I'd be interested in hearing your results with their kit and where you found a battery. Thanks Tony
11 Feb 2019 18:05 #4
  • dchallenger
I have the rex ign installed.found a 12 volt batt and head light bulb.it has not been started yet so I don't know how it runs.project put on hold for a bit.will get back to you.....
13 Feb 2019 08:29 #5
Replied by Kosmo on topic 12 volt battery
This is what you are looking for my dude: Yuasa YB3L-A - YUAM223LA
It's what I use on my 12v conversion on DT175
13 Feb 2019 09:43 #6
  • AirborneSilva
  • Online
  • Platinum Member
  • Platinum Member
Thank you!
13 Feb 2019 14:18 #7
No problem! I should have mentioned it has the exact same dimensions as the stock 6v battery.
13 Feb 2019 15:15 #8
Replied by DT125a on topic 12 volt battery
I sort of stumbled across this thread and bought 2 batteries to give it a shot. The batteries arrived today and are a tad to large for my DT400. Granted, I gave it barely a try but I'm thinking its going to require some modifying in order to fit in the same area as that 6v.
I'll take a closer look this weekend.
vic
16 Apr 2020 19:16 #9
  • Yamahamadingdong
  • Yamahamadingdong's Avatar
Replied by Yamahamadingdong on topic 12 volt battery
I have some 12v batteries from batterymart.com that should work for various 12v setups AFAIK.
I bought them all to fit in my 75 DT175, but stayed 6v and need to RMA these things.
They don't use bullet connectors so you have to fudge connections, but seem OK otherwise.
There is a 3rd battery that is too big for my 175 but I think the later ones had more room..
www.batterymart.com/p-12v-1_3ah-sealed-lead-acid-battery.html
www.batterymart.com/p-sla-1039-12-volt-2...ad-acid-battery.html
This one might be too big. It was too big for my 175: www.batterymart.com/p-12v-5ah-sealed-lead-acid-battery.html
I made bullet adapter wires but cutting the Red/Black wires off of a dead old battery, and crimping the F1 connectors to the ends.
You just need to make sure you put some cover (a rubber slip boot like what's on them), or something over the connection points!
It was pretty cool because you don't mess up the original wires, and you can just pop them right on the new batteries.
If you want to give them a shot too PM me and we can work something out before I send them back!
They're unused.
I have a trickle charger too. Used for about an hour! :)
Interesting timing, since I didn't send them back yet because it snowed and I was too lazy to go get a box at the post office!
The amp hours are lower than the flooded battery types, but if the system is charging it, to my knowledge this shouldn't really matter.
The following user(s) Liked this Post: mrstangblb
17 Apr 2020 02:46 #10
