74 DT360 throttle cable
  • dart451
  • dart451's Avatar Topic Author
74 DT360 throttle cable was created by dart451
Looking for someone that has replaced the throttle cable on the DT360 with a single cable, (no oil pump functions). I bought a Nibbi throttle cable assemply to replace the throttle cable and handle but the cable was way too short. I'm looking for something that already has the 90 degree bend on the carburetor side, straight on the handlebar side. The Nibbi has 36" and 71" and I think I need around 46-50". Anyone change theirs out?
22 Feb 2026 16:07 #1
Replied by Schu on topic 74 DT360 throttle cable
See this previous post if you are willing to keep your original cable.
yamaha-enduros.com/index.php/forums/74-7...hrottle-cable#143622
I also did it to my 400
imgur.com/a/LBDiWt4
The following user(s) Liked this Post: MarkT, pabdt
Last edit: 22 Feb 2026 16:50 by Schu.
22 Feb 2026 16:45 #2
  • dart451
Replied by dart451 on topic 74 DT360 throttle cable
Unfortunately, the cable is pretty much destroyed...so I think I need to get a single cable and rig it to the new carburetor...Thank you for your response!
23 Feb 2026 07:37 #3
  • dart451
I believe I found a cable that will work. I'll let you know when I get it...it's a 50" cable for Mikuni
Last edit: 24 Feb 2026 07:26 by dart451.
24 Feb 2026 07:25 #4
Replied by MarkT on topic 74 DT360 throttle cable
If that doesn't work, Matt at Speed and Sport can probably make you whatever you need.  www.speedandsport.com/
Motion Pro and Terry Cable are also known for making special cables.
24 Feb 2026 07:54 #5
Replied by RT325 on topic 74 DT360 throttle cable
Looks good. If its too long on the inner i just fit it up then measure how much it sits above the carb top or whatever adjuster you have--or angled bend they might have, then heat the lower brass nipple & slide it up then re-solder with soldering flux so it will take good. I try to flare the inner a bit where it sits into the slight taper of the nipple before final soldering.
25 Feb 2026 02:18 #6
