Headlight bolt size
- Enduro nut
Headlight bolt size was created by Enduro nut
Does anyone know the size of the 2 bolts that mount the headlight bucket to the mounting ears? This is for a 1975 DT250B part #97304-08025-00. I believe the size to be M6x1.00x25mm.
11 Apr 2022 20:35
Replied by Gr8uncleal on topic Headlight bolt size
The sizes and other details are very often written into the part number.
In this case, the "08025" shown in the second set of five digits means that it is M8 x 25mm and the pitch is industry standard (1.25?).
Details on how to read part numbers are often shown at the front of parts lists or at the back of service manuals. Take a few minutes to search out any original parts list (I've found the ones for early models to be the most comprehensive) and have a read through what each character means.
- goatboy56
Replied by goatboy56 on topic Headlight bolt size
I have a CT3 apart and part# 97013-08025-00 is a M8 X 25MM. My DT250B's looks the same but did not pulled the bulb out to check.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
12 Apr 2022 04:56
- Enduro nut
Replied by Enduro nut on topic Headlight bolt size
I thought the diameter was a bit small but the length seemed right but now i know! I appreciate all the help and i will definitely be looking up how to read those part numbers.
12 Apr 2022 09:45
- JGersh
Replied by JGersh on topic Headlight bolt size
If you don’t have a thread pitch gauge this Yamaha document will give you the thread pitch of all bolts used in assembly. Everything after mid ‘68 is ISO.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
12 Apr 2022 09:56
- Enduro nut
I do have a thread pitch gauge but thats a handy little sheet! i think ill hang onto that lol i appreciate it!
12 Apr 2022 20:57
