71 CT-1 won't go past 5500 RPM in 5th gear
Replied by Rick C. on topic 71 CT-1 won't go past 5500 RPM in 5th gear
Love it Tom !!!!
Run it !!
14 Apr 2022 21:21 #41
Replied by Enduronut on topic 71 CT-1 won't go past 5500 RPM in 5th gear
Hey Tom . . . .  Just a little heads up
When you get around to changing the plates and oil, make sure you use an oil that is rated for wet clutches.
Most automotive engine oils have too many friction modifiers in them, and may cause ongoing problems for you.
Look for oils that have the "JASO MA",  "MA1", or "MA2" rating.
The "MB" rating will work as well.
Good Luck,
The following user(s) Liked this Post: Rick C., Tom P
Last edit: 15 Apr 2022 00:29 by Enduronut.
15 Apr 2022 00:27 #42
  • Tom P
  • Tom P's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Replied by Tom P on topic 71 CT-1 won't go past 5500 RPM in 5th gear
Thanks for the heads up Enduronut. I've been using, Yamalube 20w-40. It says it's good for wet clutches, but it's a bit expensive for one quart.
www.amazon.com/gp/aw/d/B005BH9OB8?psc=1&...pop_mob_b_asin_title
Last edit: 15 Apr 2022 07:06 by Tom P.
15 Apr 2022 07:05 #43
  • Tom P
  • Platinum Member
  • Platinum Member
It looks like my new springs and clutch plates are going to arrive today. I didn't realize it when I ordered them, but the ebay clutch plates are coming from a city only about 30 miles away.
So from reading threads etc, the procedure as I understand it is to let the new friction plates soak in oil for at least a couple hours, put fiber in first, end up with steel, and leave the rubber O-rings out, correct?
Last edit: 16 Apr 2022 07:53 by Tom P.
16 Apr 2022 06:59 #44
Replied by Swoop56 on topic 71 CT-1 won't go past 5500 RPM in 5th gear
When using aftermarket plates , check the thickness matches stock specs .
Some aftermarket plates have proven to be thinner than stock , which can result
in a thinner clutch pack , with consequently less spring pressure on the plates .
16 Apr 2022 15:22 #45
  • Tom P
  • Platinum Member
  • Platinum Member
I got the new friction plates and springs installed, and it's working beautifully!
It turns out the old springs were close to 1 mm under spec, and the old plates measured about 3.75 mm average, and were super slick. The new plates all measured around 3.98 mm, and after I put them in, it took a lot of turns to get the push rod adjustment into the correct position.
Really wasn't a very hard job, except that when I removed the case I accidentally knocked the kick starter spring off of its post without realizing it. I already had the case back on with oil in it, and that's when I put the kickstarter arm on and realized the spring was loose.
Drained the oil, removed the case, and was able to get it in place using some baling wire fished up from underneath to pull it down, and needle nose pliers to get it on the post. At first I thought I was going to have to remove the clutch basket, but it's doable with it in place. So just a warning to check that spring and make sure you didn't knock it off to the post before you put it back together.
By the way, also make sure the steel washer is on the nylon gear on the front, it always falls off when you remove the case. I'd learned that previously.
Last edit: 16 Apr 2022 17:56 by Tom P.
16 Apr 2022 17:46 #46
Replied by RT325 on topic 71 CT-1 won't go past 5500 RPM in 5th gear
Thats good she's up & running. & this'll sound smart arse but anyway--too important to worry. You say lots of turns of the adjuter so [smart arse bit] i hope you've not dropped the ball bearing from between pushrod & the mushroom bit. I'm only saying that because 5 plates x 1/4 of a millimeter difference on each only makes 1.25mm which isn't a hell of a lot but you say had to turn adjuster in a lot of turns. I hope it only seemed a lot of turns but not in reality. Think i'll get some of those plates for my AT1.
17 Apr 2022 00:27 #47
  • Tom P
  • Platinum Member
  • Platinum Member
It's all relative. When I said "a lot of turns", in reality it was less than a quarter inch of movement. However the clutch lever was completely slack once I had the new plates installed. No danger of that ball bearing falling out though.
I'm impressed with this eBay seller.They estimated delivery by next Wednesday, and they showed up yesterday, Saturday. They ship from Walnut California, and Kentucky as well.
Only $14.39 with free shipping.
Xttps://www.ebay.com/itm/184969870432?_trkparms=amclksrc%3DITM%26aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3De478a95eef7249d59e6b8b850fa0abca%26pid%3D100675%26rk%3D2%26rkt%3D15%26sd%3D184810850344%26itm%3D184969870432%26pmt%3D1%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3Ae108cdf9-be59-11ec-ab5e-2e9712af281a%7Cparentrq%3A37e7c4e71800a7b11b05d934fffbfcba%7Ciid%3A1
17 Apr 2022 07:27 #48
  • Quartermaster35
  • Quartermaster35's Avatar
Replied by Quartermaster35 on topic 71 CT-1 won't go past 5500 RPM in 5th gear
RT325.....Thank you for the advice on the 0-ring........ I was having the same issue and the new o-ring solved it.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
03 May 2022 03:42 #49
Cheers Quatermaster35. Would be the most annoying problem with those types of carburettors & easily overlooked.
03 May 2022 04:20 #50
