1971 DT-1 MX autolube
- lolipop50
1971 DT-1 MX autolube was created by lolipop50
Today I got around to firing up the 250MX. Used pre-mix fuel so I knew it would be oiling while I checked to see if oil was arriving from the autolube pump to the intake. Yes there was oil arriving there but I wonder how much I should be seeing?? ( I just removed the banjo fitting at the intake to observe while the bike was running.) Still a considerable amount of good 'ol exhaust smoke also.
Thanks in advance for any replies.
Itching to give it a ride
12 Jan 2022 14:37
- asco
Replied by asco on topic 1971 DT-1 MX autolube
Without changing Main Jet Size ADDING PREMIX makes the bike run Lean. Beware of Lean Running 2 Strokes.
I TUNE therefore I AM
ASCO
ASCO
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
15 Jan 2022 11:31
- lolipop50
Replied by lolipop50 on topic 1971 DT-1 MX autolube
Thanks for that info on the main jets; will double check the auto-lube pump before taking it out for a ride, and then, if it's working correctly I'll rely on it for lubrication. Just an fyi: I have been using 95 octane racing fuel for all my small engines (chainsaws, weed-eaters, etc.) which I plan on using in the bike. This fuel supposedly has no added ethanols or other ingredients which degrade the fuel over time if not used right away.My other "baby" is a 1964 F-100 with the stock Y-block V8 so all this 2 cycle stuff is kind of foreign to me, I have rebuilt my truck engine and otherwise restored my truck to a good usable condition but when I look at some of the procedures for the Yamaha engine in my "Clymers" shop manual it seems to be more complex than an old school V8.Cheers
16 Jan 2022 11:40
Replied by Ht1kid on topic 1971 DT-1 MX autolube
Hey Lolipop50 does your truck have the 292 or 312 y block. These old Yamaha’s are pretty simple once you get the hang of it.
16 Jan 2022 17:17
- lolipop50
Hey Ht1kid: the V8 is a 292 in the truck.
The following user(s) Liked this Post: MarkT, Ht1kid, msavitt, Sneezles61
Last edit: 17 Jan 2022 12:34 by lolipop50. Reason: trying to add an attachment (picture)
17 Jan 2022 12:29
Replied by MarkT on topic 1971 DT-1 MX autolube
Nice!! Looks like a picture postcard scene of life in America.
17 Jan 2022 12:45
Looks great with your tag along trailer bet you get a lot of thumbs up!!!
17 Jan 2022 15:55
- adguy2112
Replied by adguy2112 on topic 1971 DT-1 MX autolube
Love the Shasta! That fam is too many for one of those now but someday…
17 Jan 2022 16:06
- my68dt1
Replied by my68dt1 on topic 1971 DT-1 MX autolube
I removed the auto line on my 68 onetime to see the feed rate. It isn't much. Good info on the main jet. Maybe that is why I stuck the new piston on my 69. Got to love those old Fords. I have two 65's one is a camper special, not as nice as yours. . Stan.
17 Jan 2022 16:17
Ford’s and Yamaha’s Thumbs up!!
17 Jan 2022 17:27
