Which carbs were painted black?
Which carbs were painted black? was created by Gr8uncleal
Just sorting out my eight various carbs and was wondering which would have been painted black originally and which not. Mine are as follows:-
CT1 x 2 - both unpainted
CT2/3 - unpainted
RT1 - unpainted (also, there is a new one on fleabay which is unpainted)
RT2 - painted black
DT3 - painted black
DT360A x2 - both painted black
More of an "inquisitive mind" question, rather than any inclination to paint any that are wrong!
When I stripped them down, only one had the correct jets and needle!
Thanks.
CT2/3 - unpainted
RT2 - painted black
DT3 - painted black
Thanks.
02 Jan 2022 07:59
- Pedalcrazy
Replied by Pedalcrazy on topic Which carbs were painted black?
I don’t know about the CTs but the rest you have correct (at least from my research and ownership)
02 Jan 2022 08:45
- Pete-RT1
Replied by Pete-RT1 on topic Which carbs were painted black?
Alan, I think the CT2 and CT3 were originally black.
I didn't like it on my CT3 so mine is now unpainted thanks to my bead blaster
Yamaha CT3 (in bits)
02 Jan 2022 08:47
- darinm
Replied by darinm on topic Which carbs were painted black?
Yes my CT2 carb was painted black originally but at this point it's about half and half
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
The following user(s) Liked this Post: Gr8uncleal, Schu
02 Jan 2022 09:54
- Bdee
Replied by Bdee on topic Which carbs were painted black?
Not sure if my CT3's carb is original, but it was black when it came into my possession,
02 Jan 2022 09:58
Replied by MarkT on topic Which carbs were painted black?
I think the general rule of thumb is the painted carbs started in the 1972 model year?
The following user(s) Liked this Post: asco, Gr8uncleal
02 Jan 2022 12:26
- Scootern29
Replied by Scootern29 on topic Which carbs were painted black?
Hmmmm, I've worked on a few original AT-CT 2&3s and haven't seen a black carb. The mx series did. Maybe there were different runs of the carbs. Some painted, some raw. Dunno.
02 Jan 2022 18:15
- Swoop56
Replied by Swoop56 on topic Which carbs were painted black?
I know the 73 enduros had painted carbs , and thought 72's were unpainted .
A look over the relative brochures tends to suggest the 72's were painted also .
02 Jan 2022 20:59
Replied by Gr8uncleal on topic Which carbs were painted black?
Thanks to all for replies, much appreciated.
03 Jan 2022 00:58
- Sneezles61
Replied by Sneezles61 on topic Which carbs were painted black?
My 72 has aluminum body, but a black cap at the slide... It also is flange mounted..
My 74 has aluminum body, but a black cap at the slide also...but its hose clamp mounted.. Is that called barrel mounted?
Sneezles61
Sneezles61
03 Jan 2022 07:33
