1973 DT3 Front fork seals will not fit
- jcalhoun
1973 DT3 Front fork seals will not fit was created by jcalhoun
I am rebuilding a Yamaha 1973 DT3. The front fork seals ordered online that are listed to fit the bike- do not. (584-23145-50 and 278-2314-51) They are 46x34x10.5mm. The problem is -there is a phalange 6mm down from the top of the front fork tube, so the oil seals stick out by 4mm. I looked on ebay and the same fork seal is listed there also. The original seal had a 46mm flat top that wrapped over and around and under the phalange. Very frustrated that a fork seal is delaying the rebuild. If anyone can help me- I would appreciate it. Thanks.
04 Sep 2020 09:30
- 1971DT250
Replied by 1971DT250 on topic 1973 DT3 Front fork seals will not fit
Post a picture of the fork tube.
04 Sep 2020 10:04
- RustiePyles
Replied by RustiePyles on topic 1973 DT3 Front fork seals will not fit
Are you certain that the forks have not been changed?
Fletch
1975 DT175B
1979 XS650
1975 DT175B
1979 XS650
04 Sep 2020 11:10
Replied by RT325 on topic 1973 DT3 Front fork seals will not fit
sounds like the shell of the old seal is still in place & only the rubber has been removed. I thought the seal had a wire circlip on top of it but might be thinking of something else.
So i've now gone looking. No5 & No4 in the link.
www.babbittsonline.com/oemparts/a/yam/50...9bc784832/front-fork
04 Sep 2020 17:09
