Engine identification
Replied by Gr8uncleal on topic Engine identification
+1
Check out CMSNL for a parts list.
Interestingly, the US model only appears to have a plate between the carb and that joint - emissions related?
31 Jul 2020 23:27
#11
- Nitto05
Replied by Nitto05 on topic Engine identification
Would a 1977 yamaha dt250 intake fit?
With a strong will you can achieve anything
01 Aug 2020 09:23
#12
- Nitto05
All my oil seals are bad so im assuming the oil seal on the other side where the clutch is is letting in oil
I csn see oio drippijg out from the magnito side
The shifter
A bolt from the bottom and the output shaft
So a new gasket set for me and some oil seals
The shifter
01 Aug 2020 09:39
#13
Replied by MarkT on topic Engine identification
Bolt pattern? Probably. Are you planning on installing a smaller carb though? Carb on DT would be smaller than IT by quite a bit.
01 Aug 2020 10:09
#14
- Nitto05
Ive got a 34mm carb that i am hoping to use so if the bolt patern is the same the intake manifold is only 40 bucks
03 Aug 2020 07:05
#15
