New top end failed - WHY? See clues...
- TheMonkey
Replied by TheMonkey on topic New top end failed - WHY? See clues...
Original piston is 65.63mm, cyl after hone was 66.04mm
Autolube primes and oozes. Clearance of lube pump matches manual spec.
The rings fit in the piston, but they had wiggle up and down in the groove that seemed like a lot. .014” thinner than rings that came out.
Thx for thoughts ?
- LongStride
Replied by LongStride on topic New top end failed - WHY? See clues...
lack of lubrication according to the side view photo of the piston
2ET703 Central Texas
24 Jun 2020 19:39
#12
Replied by MarkT on topic New top end failed - WHY? See clues...
Doing the math in my head and I'm tired but that's like 0.015" to 0.016" clearance? That's an extreme amount. Guessing it wasn't measured with correct methods or tools or there's a typo. If it really had that much clearance, I'm surprised it ran and it had to be LOUD (rattle).
Several people have mentioned "no oil"... I just want to share a couple more thoughts, most important first...
DEET is a man of few words. He gave some very good detailed advice. I'd follow it.
Primer wheel might pump oil... doesn't mean the pump is working when the crankshaft is turning.
The following user(s) Liked this Post: 2fishkev, TheMonkey
24 Jun 2020 20:22
#13
- YZBill
Replied by YZBill on topic New top end failed - WHY? See clues...
Based on your limited photos of the piston and jug, the damage is centered around your transfer ports. The piston looks like fine grit was imbedded into the piston and initiated the scuffing and aluminum transfer around the transfer ports.
Cleaning the honing grit out of the cylinder is crucial. If you don’t have a cleaning tank, use a pressure washer or throw the cylinder in your dishwasher (without soap). Just make sure to spray down the iron liner with a rust preventative, like WD-40, immediately after.
The following user(s) Liked this Post: 2fishkev, Hammer, Swoop56, Pillsbury, TheMonkey
25 Jun 2020 08:28
#14
- asco
Replied by asco on topic New top end failed - WHY? See clues...
Always a warm soap and water bath blow out with an air gun to remove metal particles. Then a clean white rag soaked in two stroke oil or marvel mystery oil wipe three times until you see no debris. I didn't see where the cylinder was bored just honed and re ringed with Wiesco. Ring gap and chamfer ...
We all have been there ...
Father and Son Cat Stevens ..
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: TheMonkey, Grussell
28 Jun 2020 22:07
#15
- Pillsbury
Replied by Pillsbury on topic New top end failed - WHY? See clues...
It looks like a few basic mistakes Good try, now you know!
Get her bored, new stock piston, rings, wrist pin & wrist pin bearing and you'll have a smile ear to ear. Have the bore job done by someone who is familiar with 2-strokes. Have fun, good luck. I think you'll be quite surprised how good she is going to run!!
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1947 Mustang
1974 Suzuki TC185
29 Jun 2020 07:36
#16
- TheMonkey
Enduronut suggested Bill Bune For machine bore work. They went 1mm over and also had a matching Wiseco piston kit.
Major cyl douche before install, and followed Enduronuts recommendations to seat the rings and break-in.
About 100 miles now, and yes - best it’s ever felt!
The following user(s) Liked this Post: Bigdog302, Swoop56, Jack
25 Jul 2020 01:30
#17
- Bigdog302
Replied by Bigdog302 on topic New top end failed - WHY? See clues...
Cheers!
Dave
Jesus is Lord!
Dave
Jesus is Lord!
25 Jul 2020 02:41
#18
