73 Yamaha LT2 100 cc won’t stay running
- Chewy812
73 Yamaha LT2 100 cc won’t stay running was created by Chewy812
Fist things first I don’t have a kick starter so I have to bump start it . When it fires up it feels like the throttle sticks open but doesn’t stay running for long. And trying to shift into neutral is very hard .
I’ve cleaned the carburetor.
08 Jun 2020 22:32
Replied by RT325 on topic 73 Yamaha LT2 100 cc won’t stay running
Need a bit more info if possible. Probably lucky it didn't run away without you if throttle stuck open. Is there a chance the throttle slide is in half a turn out--or not even half turn, but has missed the guiding peg so its on about half throttle or more. Before you go pushing again just make sure the slide is going all the way down. Carb clean out would be a good plan. Be careful that the slide needle locates into the needle jet or it'll be trying to hold the slide from going down too.
09 Jun 2020 02:04
- Chewy812
Replied by Chewy812 on topic 73 Yamaha LT2 100 cc won’t stay running
Might be possible I wasn’t to sure how to set that throttle slide up . I’ll check that out. And also I’ll do another carb clean .. thanks for the info
09 Jun 2020 04:16
- Purves
Replied by Purves on topic 73 Yamaha LT2 100 cc won’t stay running
Good advice.
When changing my coil, the first time I threw the tank back on, the cable (slide) came in contact with other surfaces and caused the throttle to stick.
Present and accounted for:
2017 Aprilia Tuono RR
1972 Yamaha LT2 100 Enduro
Appreciated, but divorced:
2015 Monster 821
Childhood memories:
2000 Yamaha YZ 125
1995 Yamaha RT 100
1994 Polaris 400 4X4
1992 Suzuki LT 160 Quadrunner
2015 Monster 821
Childhood memories:
2000 Yamaha YZ 125
1995 Yamaha RT 100
09 Jun 2020 04:40
- Chewy812
Thanks I’ll check that first
09 Jun 2020 05:23
