Brazilian dt125 s.o.s ask
  • Retrotreko
  • Retrotreko's Avatar Topic Author
Brazilian dt125 s.o.s ask was created by Retrotreko
Hi guys!gretings from Brazil.
Im restoring a 1973 dt125.
I havent any pictures or book...
Só,can tou help me find correct way tô plug wires in the generator?
The modelo in question is a 125 eletric start 12 v...
Pictures or manual Will help me a Lot!
Thanks só much
15 May 2020 08:03 #1
Replied by Gr8uncleal on topic Brazilian dt125 s.o.s ask
Welcome! from the UK.
I am not familiar with your bike, so won't try and answer. However there are free to download manuals in the Tech Library here (see top toolbar above). Even if they don't answer your immediate question, they are worth having.
15 May 2020 08:37 #2
Replied by 2fishkev on topic Brazilian dt125 s.o.s ask
Here’s a pic of a running Dt125a stator assembly. Hope it helps you. Welcome to the forum also!
15 May 2020 10:49 #3
  • Retrotreko
Replied by Retrotreko on topic Brazilian dt125 s.o.s ask
Thanks só much!!!!i Will see!!!!
15 May 2020 12:19 #4
Replied by DaveHunter on topic Brazilian dt125 s.o.s ask
Greetings right back at ya ! Looks a little different as to the amount of wire surplus that Yamaha circled around in there but final connections should be the same as on mine
Left to right ... Big pale green on left to big copper band going into starter circuit, orange from ignition coil to points, black up to voltage regulator, white to brushes + . Also there is a black ground screwed to case.
15 May 2020 15:51 #5
