AT1 no start. what am i missing?
Replied by RT325 on topic AT1 no start. what am i missing?
Won't be a compression issue @90psi. My suzuki 125 has 60psi [which i'm not proud off lol] & starts by hand--doesn't idle reliably though understandably but rockets down the road
14 May 2020 16:03
#11
- Bbd83
Replied by Bbd83 on topic AT1 no start. what am i missing?
You have enough compression and spark for it to fire it has to be carb, try starter fluid I bet it fires, revs like hell and dies and if so then you're carb needs to be assessed. Clean, rebuild, set float height and whatnot. That carb is very sensitive to float height from my experience. AFTER the clean or rebuilt if that doesn't work check your needle in the slide if/when you're in there and make sure the c clip is on top of the slide, not under.
14 May 2020 16:24
#12
I remember when i was a kid i took the carb off my old bike & poured something volatile down there [turpentine i think], it started & gave a huge rev for a couple of seconds with me hiding around the corner haha.
The following user(s) Liked this Post: Bbd83
14 May 2020 16:32
#13
- Bbd83
Funny thing is that's how I got my AT1, was helping a younger guy learn how to troubleshoot and had him kick it after the starter fluid test and it scared the crap out of him. By the end of the day the bike was mine for a mtn bike I had hanging in my garage.
14 May 2020 16:36
#14
- unclejtl
Replied by unclejtl on topic AT1 no start. what am i missing?
thanks for all the replies. I have completely disassembled the carb, soaked it, blew out all the passages and set the float level from a post I found on here. guess I will be taking it apart again to make sure. I guess I should just buy all the seals. the bike has been sitting in the desert for 20 years. I have had the stator off before from info on here so I'm becoming a pro! hahaha! I tried some brake cleaner and it "farted" a bit. I have a 12v deep cycle battery I can add to the equation for more cranking power. I have removed the spare spark plug and squirted a little gas in there and tried squirting a bit in the card, both with no results.. anyway, tomorrow i'll get back at it.
thanks for all the replies!
1969 AT1
1974 DT100
Jason Lazar
Randsburg Ca.
1974 DT100
Jason Lazar
Randsburg Ca.
14 May 2020 18:03
#15
- s900t8v
Replied by s900t8v on topic AT1 no start. what am i missing?
silly question, but you definitely adjusted the points in the direction of engine travel, aka your points are opening BTDC not after ?
1976 Yamaha AG175 cafe
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
14 May 2020 18:26
#16
- unclejtl
Yes. I’m rotating the engine counter clockwise. I find tdc with dial indicator, zero out, turn engine clockwise a bit, turn on key, test light clamped to points and ground, turn counter clockwise till light goes on, at 70 thousandths. I believe that what I read to do.
1969 AT1
1974 DT100
Jason Lazar
Randsburg Ca.
1974 DT100
Jason Lazar
Randsburg Ca.
14 May 2020 19:01
#17
- Mothersbaugh
Replied by Mothersbaugh on topic AT1 no start. what am i missing?
Please read this; I posted it a few days ago in another thread. You need to be aware of what you are creating:
Hate to jump in here with something very serious after all these good bits of humor, but remember that heat/fire and chlorinated Brake Parts Cleaner DO NOT MIX! This is how mustard gas is made. Be careful, you back yard chemists. I'd hate to see someone spray the silencer full of chlorinated Brake Parts Cleaner, have a little pool left in there that didn't evaporate, and then throw it on the fire. Upwind.
Be careful out there!"
Get some ether-based starter fluid if you want to spray something in there. Live long and prosper.
The following user(s) Liked this Post: Rick C., Bbd83
14 May 2020 20:49
#18
- unclejtl
Good advice. Thanks
1969 AT1
1974 DT100
Jason Lazar
Randsburg Ca.
1974 DT100
Jason Lazar
Randsburg Ca.
14 May 2020 21:55
#19
- Davey
Replied by Davey on topic AT1 no start. what am i missing?
Talk to her nicer and maybe take her out for a nice dinner
14 May 2020 22:42
#20
