starting 1978 dt 250
starting 1978 dt 250 was created by ba
hasnt run in long time but started up easy lights flashing on tach dont want to mess it up what u all think oil level ok
10 Apr 2020 10:02 #1
Replied by FrankC on topic starting 1978 dt 250
If transmission fluid is up to the correct level and if there is 2 stroke injector oil in the auto lube tank. I'd make sure that there is smoke coming out of the exhaust. Normally people verify that the oil injector pump is working all the while running pre mix in the gas tank. Then upon verification switch to auto lube only. But if you have smoke then probably all okay. One.test I do is pull the oil line from the carb for a few seconds and look for a dribble of oil, less at idle, more as the bike is reved. Careful when pulling the oil line from the carb, as it easily rips apart. There is a metal spring hose clamp there. Needle nose pliers with a twisting motion while pulling hose helps.
Last edit: 10 Apr 2020 11:46 by FrankC.
10 Apr 2020 11:03 #2
Replied by ba on topic starting 1978 dt 250
all tack lights flashing head light oil light and blinker battery dead could that be it
10 Apr 2020 11:55 #3
The headlight run on the ac side so I am thinking the battery would not effect that. Unless you are saying the high beam indicator is flashing. Maybe someone who knows more will chime in.
Last edit: 10 Apr 2020 15:28 by FrankC.
10 Apr 2020 15:27 #4
Replied by Mothersbaugh on topic starting 1978 dt 250
By flashing, do you mean irregularly or steadily, as if the headlight and dash lights somehow got wired into the turn signal flasher?
10 Apr 2020 18:24 #5
Replied by MarkT on topic starting 1978 dt 250
Makes perfect sense with a bad battery especially if turn signal on.
Not a great idea to run these bikes with a bad battery as it can lead to blown bulbs... but yours should have the factory voltage regulator so not nearly as likely.
A video or better description would be helpful. Could just be "flickering" at low rpm because of bad battery or could get alternating flashing of dash lights with turn signal on again due to bad battery.
10 Apr 2020 18:35 #6
Has anyone been in the switch? Sometimes guys don't get it reassembled correctly, and the right things line up in the wrong places, causing strange goings on.
10 Apr 2020 18:39 #7
thanks for reply turn si gnal was on oil light come on in neutral this forum is good answer back guickly and helpfull thanks
10 Apr 2020 19:07 #8
Sounds like there could be something amiss in the switch. One plate slides over the other, and if the one moving is off space by a slot, or if one is upside down, then things go haywire quickly.
10 Apr 2020 19:18 #9
Replied by Gr8uncleal on topic starting 1978 dt 250
Oil light should come on when bike is in neutral - this is to show it is working properly. If it stays on, or comes on, when you are in gear/riding, then it's likely that the two stroke oil level is too low.
As well as a possibly faulty switch, has the wiring in the headlight bucket/shell been checked to make sure that all colours connect correctly?
11 Apr 2020 01:33 #10
