What's one of these called
- Godlygaz
What's one of these called was created by Godlygaz
The little rubber thingy that are used to protect and to separate the metal from the bolt/ frame
Tia
Sent from my POCOPHONE F1 using Tapatalk
Tia
05 Apr 2020 04:15
- Godlygaz
Replied by Godlygaz on topic Re:What's one of these called
Ok so I failed at this , a quick Google - it's a grommet ..
Forget I said anything .... : )
05 Apr 2020 04:17
Replied by Gr8uncleal on topic Re:What's one of these called
No problem asking Gaz, different folks/companies have different names for various items and some of them are not very obvious!
05 Apr 2020 05:06
- 1971DT250
Replied by 1971DT250 on topic Re:What's one of these called
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=272596607540&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Yamahamadingdong
Replied by Yamahamadingdong on topic Re:What's one of these called
well I'm glad you asked so now I know.
There was one when I was swapping horns out and I was just referring to it as "rubber nut thingy".
Fortunately mine wasn't ruined, it was just pushed into the hole and needed popped out to be normal again.
06 Apr 2020 10:26
- Slipkid
Replied by Slipkid on topic What's one of these called
Grommet was mentioned, I've also heard them referred to as isolators.
07 Apr 2020 11:47
- yamahoper
Replied by yamahoper on topic What's one of these called
I worked in Japanese three brand Dealership back in the 80s. One of the challenges was learning what each brand called a particular part, then what group it would be shown in on the microfish. Yamaha does call it a grommet, Suzuki calls it a cushion. I often look to a parts diagram on Partzilla or similar so I get it right. We had quite a few laughs when a customer would call in for a stock check with a slang name for the part ; )
07 Apr 2020 13:00
- Eazy-X
Replied by Eazy-X on topic What's one of these called
Always worth getting a "selection box" of grommets from eBay, Amazon, etc. Helped me out a lot with my rebuild
07 Apr 2020 17:56
