DT2 Tank Disaster
- htw123hotmail
DT2 Tank Disaster was created by htw123hotmail
had my DT2 tank sandblasted recently and the outer neck, which turned out to be pot metal, disintegrated. the inner neck sleeve, which is steel, is fine, but now I can't use my gas cap! anything I can do short of getting a new tank?
thanks!
thanks!
- YAMABOBINTEXAS
Replied by YAMABOBINTEXAS on topic DT2 Tank Disaster
If it turns out you can't salvage it, I have a used tank that is straight but needs to be painted that I could sell you. It's premiered right now. Here's a couple of pictures of it. PM me if interested.
YAMABOB
YAMABOB
18 Jan 2020 11:05
- 1971DT250
Replied by 1971DT250 on topic DT2 Tank Disaster
The outer portion that holds the gas cap came off of one of mine while soaking in phosphoric acid. It is low grade metal.
I like the original cap design on the '71 and earlier tanks.
18 Jan 2020 11:50
- Elpho
Replied by Elpho on topic DT2 Tank Disaster
Depends whether you just want a restored bike, or are in this for the technical challenge. It would be possible to machine up a ring in steel, braze on the extensions and then grind and file the necessary shapes. A Dremmel would be handy. Then attach with JB Weld. It would be a slow process but very satisfying.
18 Jan 2020 11:55
- Super90
Replied by Super90 on topic DT2 Tank Disaster
YAMAHABOBINTEXAS, if the first guys doesn't want the tank I'll take it. I need one bad now as the "liner" the POV put in the tank has all come loose and I discovered that my tank is full of rust. ouch. I tried the messaging system but could not get it to work so....my e-mail is This email address is being protected from spambots. You need JavaScript enabled to view it.. thanks, tim in florida.
18 Jan 2020 12:34
- YAMABOBINTEXAS
I just sent you a PM Tim.
YAMABOB
YAMABOB
18 Jan 2020 12:47
- Super90
Photos of my DT3 tank disaster. Taken today. When I bought the bike it appeared that the "liner" material on the left inside was coming loose. I never tried to clean out the tank being worried about what might happen. But, I am having to change inline fuel filters a lot and clean the carb a lot I thought I would clean it out. When I dumped the remaining fuel out into a bucket I was astounded at the dirt and trash that was lurking behind the loose liner. I tried to remove it and was able to gently keep tugging on the liner and after several hours. I had removed what you see here. I have rinsed it out multiple times, blown it out with air and it is "pretty" clean but I think so much rust came out attached to the liner that my tank won't last long. I want to be a good neighbor here so if the first guy wants the tank bob has then let him have it...but if not, well, you see what I have and it ain't pretty. No wonder my filters and carb kept getting loaded up. Oh well, I still love this bike!
18 Jan 2020 12:57
- YAMABOBINTEXAS
The original poster of this thread is a newbie on the forum so not sure what his habits are about checking in on this site. I'll send mim a PM later and if I don't get a response, I'll reach out to you.
YAMABOB
YAMABOB
18 Jan 2020 13:13
- htw123hotmail
Replied by htw123hotmail on topic DT2 Tank Disaster
I do too. I wouldn't mind converting it if I could get the outer neck.
18 Jan 2020 13:31
Replied by MarkT on topic DT2 Tank Disaster
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=222780189902&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
