EARLY YAMAHA'S 1959 -63 YDS's
Replied by MarkT on topic EARLY YAMAHA'S 1964 -65 YDS2 YDS3
Dave,
I'd look into hydroforming the pipes... would give you more of a "stamped steel" look and from what I've read can be done fairly easily with a standard pressure washer as the pressure source. Those pipes might be very easy since the expansion chamber looks pretty straight after the head pipe. (I've read that hydroforming gets tricky when forming curved pipes.)
You might even be able to "crimp" the seams and make them look perfect!
Keep up the great work!
Hope I get to see it in person someday.
23 Aug 2015 20:33
#141
- Visitor
Replied by on topic EARLY YAMAHA'S 1964 -65 YDS2 YDS3
Mark....I had been contemplating hydroforming them also !
It could be a very slick way of doing it ?
24 Aug 2015 13:47
#142
- bluntz465
Replied by bluntz465 on topic EARLY YAMAHA'S 1964 -65 YDS2 YDS3
Another way to prototype the pipes is to spin them,you can make several on a lathe in a day.Once you get your flow right then you can transfer the dimensions to your hydro pattern or traditional sectional pattern.The header curve is no easier but maybe talk to a muffler shop to bend it for you.But maybe you may like a light muffler?
1982 Yamaha IT465J
1982 Yamaha IT465J
The following user(s) Liked this Post:
- Visitor
Bluntz very interesting idea.....
thanks for the post !
24 Aug 2015 19:52
#144
- Visitor
Hi Mark,
Are you talking about something like this ?
It seems like it could be a time consuming process....
maybe making them out of stainless ????
Why don't I send someone here the dimensions I need and you make them for me ?
- Scootern29
Replied by Scootern29 on topic EARLY YAMAHA'S 1964 -65 YDS2 YDS3
The second video is hilarious but....... really cool. You can do it Dave.
25 Aug 2015 15:19
#146
- Visitor
Has anyone here tried hydroforming ????
Anyone else have opinions or knowledge on the subject ?
The Ascots pipe do lend themselves to that hydroformed look....
- Visitor
Decided to pull out the Ascot's TD1 cylinders and clean them up a bit.
Things were even more simple back then...notice the single transfer on each side of the bore.
This was referred to as a 3 port design...Yamaha being a leader in two stroke technology introduced the 5 port layout design sometime around 1965 or 1966 ?
- Visitor
Yamaha appears to have standardized things very early ...
as the intake stud spacing is the same at the AT/CT.
I like how the intake ports were cast...nice straight path into the crankcase
The exhaust ports have lots of area to work with
I did a quick "knockdown" the major casting flaws
and will be keeping the port timing stock.
No porting....just polish !
I haven't checked the piston clearances on either jug yet.
- Hemibusa37
Replied by Hemibusa37 on topic EARLY YAMAHA'S 1964 -65 YDS2 YDS3
What's the actual cc's of each cylinder and how much HP rating in stock tune?
28 Aug 2015 10:35
#150
