Dt 250 1972 no spark
- hbbdiesel
Dt 250 1972 no spark was created by hbbdiesel
Good day, need advise , i have light on my test light on both green and black , but no spark on the plug, my key is on , what my next steep?
Thank
Thank
23 Nov 2019 10:27
- shyted
Replied by shyted on topic Dt 250 1972 no spark
Hello hbdiesel.
Pull the generator cover off and see if you get a spark at the points .
No Spark?
Then the next step would be to down load the correct manual from the TECH section on the title bar of the forum header, for your motorcycle and follow the test procedures .
There's also several Vlogs on the internet showing the testing of ignition items on you tube. They test points and condenser, ignition timing,field winding's on the source coil and testing the HT & LT sides of the coil
That should point you in the right direction chief .
Regards Ted.
No Spark?
Regards Ted.
24 Nov 2019 02:06
- hbbdiesel
Replied by hbbdiesel on topic Dt 250 1972 no spark
I spin the engine whit à drill ,i have power at the entry to the coil, but nothing after the coil to the Spark plug.this make me think my coil is cook. This bike was nut running when i got It.i change the point plate condenser from a identical bike,put back the flywheel magneto.
Just not shure if is the coil for sure.my service manual is for a dt1 my bike is a 1972 250 my serial numéro start whit dt1fxxxxxx whitch manual should i use? Thank.
24 Nov 2019 13:45
- bluntz465
Replied by bluntz465 on topic Dt 250 1972 no spark
Try a known good plug
1982 Yamaha IT465J
1982 Yamaha IT465J
24 Nov 2019 15:18
- shyted
71-73 DT & RT (250cc-360cc) Service Manual
Go to the service manuals and look for this heading.
I copied it directly and pasted it here.
It should give you a test to do on the coil with a multimeter
24 Nov 2019 16:43
