British AT1 owner
- Tommyuk
- Topic Author
British AT1 owner was created by Tommyuk
Hi all!
my names Tom, I live in Margate, England and I have a USA imported AT1 1971 that I’ve owned for around 3yrs. Stripped and rebuilt but kept the patina.
it’s road registered but I mostly use it for light off-roading at events like the Malle mile .
looking forward to drawing on the knowledge of the forum to try and rectify my running issues and helping others where I can.
cheers
tom
cheers
tom
Replied by RT325 on topic British AT1 owner
Welcome from NZ. I have a similar but older AT1. Yours "should" be "72 or "73 in theory because i can see the reed valve inlet, plus tank is "72-3. All a small point but could become a big point if ordering parts. & just to confuse 'us owners' Yamaha in their wisdom used AT1 prefix from "70 until "73 inclusive. Any problems please ask away. Is yours electric start as most of the US ones appear to be [12 volt battery ignition etc]. Mine is magneto ignition & kick start only which we got here & in Australia. Well, we got both but Mag ones were a better seller & performed a bit better as not having to spin the heavy generator starter setup. Anyway--your having lunch & i'm going to bed. Cheers from half a world away.
19 Apr 2023 04:59
Replied by Ht1kid on topic British AT1 owner
Greetings from Tennessee.
19 Apr 2023 05:31
- Tommyuk
- Topic Author
Replied by Tommyuk on topic British AT1 owner
Thanks guys.
I think I was having a brain fart yesterday. Mine is an AT2 , according to the vintage Japanese motor cycle club. Even though both frame and engine number begin AT1 !
Manufactured in November 1971
yes it’s electric start. I’m hoping to change it to magneto if I can find the parts.
cheers
tom
cheers
tom
20 Apr 2023 11:24
Replied by MarkT on topic British AT1 owner
Crank stub is different on magneto model so it's not just a matter of finding a Yamaha magneto
You can get a modern 12v CDI magneto from VAPE. No more battery required to run and no more electric start.
20 Apr 2023 11:35
- BadaBing
Replied by BadaBing on topic British AT1 owner
Hi tom, if i can find an oversize piston for my rt2 it will be at the malle mile, if I can’t find one it will be the rattlyist bike there. Either way see you there.
The following user(s) Liked this Post: RT325, Sneezles61
22 Apr 2023 00:20
BADABING #6, Welcome & wow your RT2 looks nice, very nice.
22 Apr 2023 00:37
- BadaBing
Thanks, was a little side job that nearly didn’t happen but glad it did now.
22 Apr 2023 01:38
I copied the info on the VAPE below:
I helped Powerdynamo develop the kits for the 125 and 175 Yamaha Enduros. They had a confused mess originally from building kits for owners and their dimensions and had roughly 15 very similar kits. I did a lost of test fitting and narrowed it down to 3 kits that fit all the US models. The owner sold to his main part supplier, VAPE, when his health declined. VAPE has kind of made the catalog hard to read. The old Powerdynamo listings are still there though. www.powerdynamo.biz/deu/systems/lists/yamaha.php
Scroll down the listing and you'll clearly find your bike... www.powerdynamo.biz/eng/systems/7729/7729main.htm
Then you can go to the VAPE shop and find your kit... they have it listed under the DT125E. Not sure why the price is higher than the CT kits? Used to be about the same. Could be the rotor on the electric start models is a lot heavier so Powerdynamo used a heavier flywheel. Maybe that flywheel got more expensive? If you can talk to VAPE, they can machine the lighter CT flywheel to fit your crank if that's the issue with the price.
www.vape.eu/en/yamaha-dt125-e
23 Apr 2023 08:04
