Fuel tank repair?
  • Flint
  • Flint's Avatar Topic Author
Fuel tank repair? was created by Flint
Done a search but didn’t come up with anything. Did anyone have luck repairing a cracked plastic tank? Mine is a 79 IT 175 with about a four inch horizontal crack at the lower waterline. Methods or types of adhesives? Thanks
24 Jun 2022 12:26 #1
  • Flint
Replied by Flint on topic Fuel tank repair?
I’m thinking scuff it, clean with acetone, warm with heat gun and hot glue it.
Just thinking the hot glue might be fuel resistant.
24 Jun 2022 12:57 #2
Replied by Ht1kid on topic Fuel tank repair?
I would buy another tank. Fire hazard being that close to your exhaust
24 Jun 2022 17:13 #3
  • Flint
Got a tank on order for about two months.
24 Jun 2022 22:45 #4
  • Flint
Took a pellet of hot glue and soaked it overnight in premix. The glue will desolve so that won’t work.
26 Jun 2022 08:36 #5
  • Tom P
  • Tom P's Avatar
  • Platinum Member
  • Platinum Member
Replied by Tom P on topic Fuel tank repair?
I've used hot glue where it's been submerged in water and it holds, but I didn't think it would stand up to gasoline. I know a lot of people repair RV holding tanks with plastic welding, you might look into that as a temporary measure. I've never done it, but I think you can buy a kit fairly inexpensively.
Here's a guy just using a soldering iron, as Mauser suggested, and he cut off a little piece of donor material from a fender.
Last edit: 26 Jun 2022 09:09 by Tom P.
26 Jun 2022 08:50 #6
They make fiberglass repair kits for plastic
26 Jun 2022 08:58 #7
If it was mine I would do both plastic repair and fiberglass on top for better protection until your new tank arrives
26 Jun 2022 09:29 #8
  • Flint
Bought one of the rather expensive plastic welders from Harbor Freight Tools today. I’ll make a practice run or two on my old beat up quad.
26 Jun 2022 15:17 #9
Replied by darinm on topic Fuel tank repair?
Those more expensive ones are much better than using a soldering iron or heat gun. Once you get the temp set for your particular plastic, it's not too bad to make a good weld, they can come out looking just like a metal weld with some practice.
It is best to match similar plastic for the best results when welding. In the kayaking world there is some excess plastic on the cockpit rim of the boats and we cut that to weld with so it's from the same production run. If you want to pay shipping I can send you some plastic I recently took off my IT200 as I went with a DC plastics kit, would be a side panel, which looks like it was rotomolded like the tank.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
26 Jun 2022 19:57 #10
