DT360A hose to oil pump.
  • Gr8uncleal
  • Gr8uncleal's Avatar Topic Author
DT360A hose to oil pump. was created by Gr8uncleal
Is this the correct route for the oil pump hose, once it enters the cavity? It's not obvious in my photo, but it's really easy to pinch the hose in such a tight space.
Thanks.
01 Aug 2025 10:19 #1
Replied by pabdt on topic DT360A hose to oil pump.
Al, I had the same exact thought recently and somewhere in Yamaha docs I saw a picture of it exactly as you have routed.  I think under the engine source tubing, maybe slightly lower.   I have tested mine and it puts out qty as expected.  going to find the resource I mentioned...IF I can find it.
edit:  Page 24 Service Manual has a picture.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, Gr8uncleal, Ht1kid
Last edit: 01 Aug 2025 14:10 by pabdt.
01 Aug 2025 14:04 #2
  • Gr8uncleal
Replied by Gr8uncleal on topic DT360A hose to oil pump.
Thanks very much.
01 Aug 2025 23:11 #3
  • john.lockwood5@bigpond.com
  • john.lockwood5@bigpond.com's Avatar
Replied by john.lockwood5@bigpond.com on topic DT360A hose to oil pump.
Is it possible to move the brass elbow the pipe is attached to, to a better angle?
02 Aug 2025 00:11 #4
  • Gr8uncleal
Maybe, but, knowing my hamfistedness, I'd probably damage something!
Last edit: 02 Aug 2025 05:17 by Gr8uncleal.
02 Aug 2025 05:16 #5
Replied by Swoop56 on topic DT360A hose to oil pump.
The inlet nozzle is a press fit into the pump . It may twist to a better angle relatively easily .
Looking at your picture , you'll only be able to make a slight adjustment , but that's probably all you need .
I've done it on my RD 400 pump , and it moved easily , but on another pump I tried , it wouldn't budge .
Last edit: 02 Aug 2025 14:41 by Swoop56.
02 Aug 2025 14:38 #6
Replied by MarkT on topic DT360A hose to oil pump.
A good kink in the hose does save on oil.
Can't tell from pic too well but make sure there isn't a "high loop" in the bend that will trap air bubbles.  Should be a nice downhill sweep.
02 Aug 2025 15:03 #7
