Oil line replacement
- Yamalol
Oil line replacement was created by Yamalol
Hey folks,
Looking for a recommendation for a replacement oil line going from the oil pump to the engine on my 1974 DT250. The old oil line is brittle, and cracked when I removed the banjo fitting. The ID was easy enough to match at my local auto parts store, however the OD on all of their offerings is far to big.
'74 DT250A, ‘69 Honda SS125A, ‘88 KLR 650, '57 Harley-Davidson Sportster, '46 Harley-Davidson WL.
14 Apr 2025 11:13
Replied by MarkT on topic Oil line replacement
Yamaha still sells it along with the correct little coiled spring steel clamps if needed. #19 is the hose, #20 is the clamps
www.partzilla.com/catalog/yamaha/motorcy...1974/dt250a/oil-pump
14 Apr 2025 11:55
- Yamalol
Replied by Yamalol on topic Oil line replacement
Great, thank you!
14 Apr 2025 12:02
Replied by Gr8uncleal on topic Oil line replacement
Fuel and oil pipes/hoses are generally now supplied in standard lengths, so you might need to cut to your required length. As always, measure twice, cut once!
14 Apr 2025 23:55
Replied by RT325 on topic Oil line replacement
If you use just an accessory piece of hose be sure it's not too thin which could link easy if you have a sharp bend. Just gentle curves is good.
15 Apr 2025 04:31
Listen to Alan... unfortunately my experience is often something like "I cut it twice and it's still too short!"
The following user(s) Liked this Post: Schu, Ht1kid, Sneezles61
15 Apr 2025 12:10
15 Apr 2025 12:30
