Mikuni VM24ss float height
- DTTimClark100860
Mikuni VM24ss float height was created by DTTimClark100860
Hi all …do I measure the 21mm float height from the lower rim of the casing ie the underside of where the gasket sits or from the top of the gasket?
many thanks in advance
Tim Steve
Tim Steve
01 Apr 2025 23:02
Replied by RT325 on topic Mikuni VM24ss float height
Personally I never remove the gasket as with my luck it'd break & not have a spare. I'm not sure what they say officialy but they normally allow a bit of leeway in there measurement plus or minus each way. Sorry, no help am I. I mostly just go by guesswork so not good.
The following user(s) Liked this Post: MarkT, DTTimClark100860
02 Apr 2025 01:42
Replied by MarkT on topic Mikuni VM24ss float height
Method is different depending on year and model. Early models sometimes measured down from needle jet. Plus Yamaha specs can vary, one of the Factory Service Manuals shows multiple specs for the same model in different parts of the same manual.
I stopped measuring a long time ago and just set the float arms parallel to bowl gasket surface when float needle closes. Never failed me. If you go by spec, make sure when you're done the arms should be parallel or nearly parallel to gasket surface. If not, then the spec you used and/or measurement method is incorrect for your carb.
The following user(s) Liked this Post: DTTimClark100860
02 Apr 2025 07:54
- SCOTTE36AT1
Replied by SCOTTE36AT1 on topic Mikuni VM24ss float height
It’s 21mm with a tolerance of 2.5mm and you can measure it from the gasket surface (so on top of the gasket). The gasket should be 1mm, (at least mine is) so what ever you measure so just subtract 1mm.
The following user(s) Liked this Post: RT325, DTTimClark100860
