75 400 enduro problems
  • Lawsonj5
  • Lawsonj5's Avatar Topic Author
75 400 enduro problems was created by Lawsonj5
New member here and was just given a 75 400 enduro.  I’m a Jeep guy but not very familiar with bikes. The Bike hasn’t ran in years.  I cleaned the tank and fuel shutoff, new spark plug, tore apart carb and cleaned but no new parts. I can get the bike to fire up but only when choked.  As soon I turn the choke off it dies.  Also, I’m 4-5 turns out on the mixture screw just to get it to idle.  Can’t give it any throttle or it dies.  Any input is appreciated.
I found a carb kit for 77-78 but nothing for 75.  Anybody have a part number for rebuild kit?
11 Nov 2024 14:16 #1
  • pahiker
  • pahiker's Avatar
Replied by pahiker on topic 75 400 enduro problems
Sounds like low speed circuit or pilot jet is obstructed. I dunked my carb in Berryman chem dip and others reported good results with ultrasonic cleaner to ensure the gunk in those small areas is removed.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
The following user(s) Liked this Post: pabdt, Ht1kid
11 Nov 2024 14:26 #2
Replied by Ht1kid on topic 75 400 enduro problems
Greetings from Tennessee
11 Nov 2024 16:14 #3
  • Reed valve Richards
  • Platinum Member
  • Platinum Member
Replied by Reed valve Richards on topic 75 400 enduro problems
Hey there Lawson, you are half way there. Other people on here will give much better advice than I can, but you might try
going through the carb checking all the jets and orifices as the choke system obviously works
there are many other things (like a clogged pipe...) but usual checks would be
air filter and air filter box leaks
all rubber fitting from carb to bike for leaks
throttle slide correctly seating all the way down and adjusted at throttle
having everything at standard settings may help, so check the needle is seated and clip position
those are some things that I would be doing,
Yo Joe, Go Joe
11 Nov 2024 20:43 #4
Replied by RT325 on topic 75 400 enduro problems
Welcome from NZ. Something's not as it should be if you have the mixture screw 5 turns out.
Must be nearly falling off the thread.
It's in for rich & out for lean so set it at 1.5 from fully in.
That might help it get through the initial leanness off idle.
It's important to remove the jets & the center long needle jet plus the idle mixture small jet up in the body to be sure its clean. Maybe you're used to carbs with fuel screw out for rich but these are air screw so in for rich--ie--less air.
Could raise the slide needle by 'lowering the clip' to get it through the mid-range.
Possibly a crank seal but they're pretty robust on those so stick with the carb at this stage i think.
Last edit: 12 Nov 2024 13:09 by RT325.
12 Nov 2024 13:07 #5
Replied by pabdt on topic 75 400 enduro problems
Pahiker, thanks for remedy. I've got a carb now that needs cleaning.
Lawson, make sure you have fuel coming in, float is somewhat level to carb base in general, and all is clean. make sure the holes on the inlet of the air filter side of carb are clean. no airflow there = no suction through low speed jet.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, Ht1kid, pahiker
12 Nov 2024 21:49 #6
Replied by concours on topic 75 400 enduro problems
Bribe a friend that has real motorcycle carb skills using booze as needed.
The following user(s) Liked this Post: Starrblade
06 Apr 2025 17:50 #7
