1976 DT100
- yamahahaha
1976 DT100 was created by yamahahaha
I'm not to schooled on clutch side of an engine and/or the photo here..Does anyone see any issues or problems just from this photo???
I'm not looking for anything in particular just want to know if things look correct if that makes sense
06 Oct 2020 17:20
Replied by MarkT on topic 1976 DT100
Other than missing parts?
06 Oct 2020 18:11
- yamahahaha
Replied by yamahahaha on topic 1976 DT100
Now that you mention it, what parts are missing???
06 Oct 2020 22:50
- Eazy-X
Replied by Eazy-X on topic 1976 DT100
The clutch basket!
but I guess you knew that
Seriously though, how about the plastic tacho gear? (Does the DT100 have a rev counter?)
Replied by RT325 on topic 1976 DT100
Only thing i can see -- "can't see" is no thin washer on the kick start shaft against the circlip to stop circlip chewing the case. Washer is probably in the oil tray or still in the cover. Is this a trick question. Nearly tricked 'me'.
- yamahahaha
No tricks RT.. I only play tricks when I'm holding all the cards and I'm NOT holding them in regards to my initial question
07 Oct 2020 04:50
- yamahahaha
Yes on the clutch basket. I don't know about the rev counter, hopefully someone will weigh in on that also
07 Oct 2020 04:52
Replied by Gr8uncleal on topic 1976 DT100
The DT100s that I've seen haven't had rev counters.
The following user(s) Liked this Post: JayB, Eazy-X
07 Oct 2020 05:14
The whole clutch is missing... and yes, no shaft or plastic gear for tach drive but DT100 didn't have them
The following user(s) Liked this Post: yamahahaha, JayB
07 Oct 2020 06:16
- yamahahaha
I checked Partzilla and CMSNL for the clutch assembly. It only shows a 1977 DT100 clutch assembly as compatible. Does anyone know any differently?
07 Oct 2020 08:36
