crankshaft seal orientation on 1974 Yamaha DT360!
- msavitt
crankshaft seal orientation on 1974 Yamaha DT360! was created by msavitt
Hi all -
I am replacing the clutch on my 1974 DT360A and decided to replace the crank seals since they are likely leaking (i am the guy with the daahh daaahhhh dahhhh dahhh deceleration and no air leak elsewhere.
Popping them out was easy using a couple of longer drywall screws after drilling a couple of very small holes with a low speed bit coated in grease to catch the shavings
MY QUESTION IS the seals I removed hat the flat side of the seal - the one with the manufacturing markings that you typically place the seal driver (er um socket) against facing in towards the main bearings. I am assuming that I removed factory installed seals and this orientation was proper but wanted to be sure, so i am asking...is this orientation OKAY?
thanks
Martin post 2 :-)
OC CA
thanks
Martin post 2 :-)
OC CA
26 Jul 2020 13:20
- msavitt
Replied by msavitt on topic crankshaft seal orientation on 1974 Yamaha DT360!
lips facing transmission oil...i think i just may have answered my own question
26 Jul 2020 13:25
- akara1
Replied by akara1 on topic crankshaft seal orientation on 1974 Yamaha DT360!
If you have a factory crank seal with the bumps on the edges like the one pictured
www.picclickimg.com/d/l400/pict/26444936...l-93103-38086-00.jpg
the side with the bumps goes IN towards the crankshaft.
If you have aftermarket single lip crank seals, install them with the spring side in towards the crankshaft, and letters out, and make sure not to install them deeper than flush, or else youll block the oil hole to the main bearing.
26 Jul 2020 13:27
- msavitt
thanks!
That's how i found them and how i will replace them too since i got NOS
okay - another one for you if that's okay
the needle bearing under seal for clutch bell crank thing...I see no form of retention beyond friction in manuals or on bike, so what's best way to pull it out?
26 Jul 2020 13:50
- akara1
if you dont intend to reuse the bearing, a pilot bearing puller kit or a blind bearing puller kit from amazon will do the trick, especially if the case has been warmed up
26 Jul 2020 14:42
- tlh0824
Replied by tlh0824 on topic crankshaft seal orientation on 1974 Yamaha DT360!
I am working on my first engine rebuild and tried a leak test, the primary gear seal leaked miserable. (I did have the bumps facing out) Do you add any rvt black , or grease?
- msavitt
if you pin pointed the leak to the seal then only option I see is to remove it and replace in proper orientation
i have built many engines and would never use RTV on a deal or any internal part other than very lightly coating a gasket, or split seals on an old american v8 intake manifold or rear main seal as specified
26 Jul 2020 19:42
- msavitt
thanks!
i will def warm up the case
26 Jul 2020 19:42
- akara1
there is an o-ring that goes behind the primary gear that prevents air from being sucked through the splines, also on some other 2-stroke yamaha air can leak past the square keyway so motoseal works there to stop it leaking
26 Jul 2020 19:49
- tlh0824
Just to confirm picture "A" goes crankshaft side in "B" faces outside, and the seal should just be flush with the case
29 Jul 2020 16:12
