Dynamo Cleanup - >> worth it. DT125A
  • pabdt
  • pabdt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
so today, took the DT125 dynamo apart for cleaning. Been wanting to do this for a while. Found lots of carbon and glazed/caked on deposits. As a bonus, polished the case, and cover on re-install.
Before:
6 o'clock position = not cleaned, 7 o'clock = cleaned.
After:
Bonus:
Tools/chemicals used:
600 grit sandpaper (per service manual), Chem B-12 spray, very fine alum oxide pad, and an air gun. I did put the 12 mm yoke bolt in and spin in a few times w/the drill also (no spark plug installed).
Also, lightly sanded off the end of the brushes to allow them to reseat.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, mdscott
Last edit: 21 Sep 2019 21:28 by pabdt.
21 Sep 2019 21:20 #1
