DT2 lost spark
- AirborneSilva
DT2 lost spark was created by AirborneSilva
Bike had good spark now nothing! Battery is fully charged and putting out 6.25 volts. Any help would be appreciated! Thanks, Tony
17 Apr 2022 15:33
- Bigdog302
Replied by Bigdog302 on topic DT2 lost spark
I bet you have dirty points causing the lack of spark. the battery is not needed for spark.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
17 Apr 2022 17:07
- asco
Replied by asco on topic DT2 lost spark
Unplug the Test Leads.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
17 Apr 2022 20:19
- AirborneSilva
Replied by AirborneSilva on topic DT2 lost spark
I did pull the flywheel off to check them out, they look a little burnt to me. Should I try cleaning them with 600 sand paper? Looks like points and condenser would be a pain to change...
18 Apr 2022 01:00
- AirborneSilva
Not sure what you mean.
18 Apr 2022 01:01
Replied by RT325 on topic DT2 lost spark
Just give them a scratch with some emery paper but not very coarse grit stuff. Make sure there's no grit left behind & see what happens. Can just lightly tighten the flywheel nut for turning it over looking for spark on the kick start or spinning with a drill.
18 Apr 2022 01:42
- AirborneSilva
Thank you, I'll give that a try.
18 Apr 2022 01:49
- AirborneSilva
Don't have any emery cloth so I used the 600 that I had, ran it through a few times, still no spark...
18 Apr 2022 14:39
- Schu
Replied by Schu on topic DT2 lost spark
Kill switch?
I never use mine, which is why I ask about it.
I think my son flips it to the off position just to mess with me…..
18 Apr 2022 14:47
- AirborneSilva
Thank you! I wish it were that simple, the DT2 doesn't have a kill switch.
18 Apr 2022 14:52
