Wiring
- TIGER500
Wiring was created by TIGER500
Anybody know where the rectifier is hiding .as still bowing headlight bulb.Also a couple of unconnected wire s from loom . Photos.
08 Dec 2021 03:50
- Jammyyammy
Replied by Jammyyammy on topic Wiring
Mine was on the back of the headlamp bowl…
08 Dec 2021 04:20
- mike8162
Replied by mike8162 on topic Wiring
Looks like a DT3. Should be mounted on the frame right behind the steering tube in front of the coil on the magneto side. Little M5 screw if I recall correctly. If the tank is off and you don't see it, it is not there.
Cheers
Cheers
08 Dec 2021 04:30
- TIGER500
Replied by TIGER500 on topic Wiring
Found it thanks behind coil under tank
08 Dec 2021 04:40
- TIGER500
Thats where it was coverd in crun diagram showed it next to battery .thanks
08 Dec 2021 04:42
Replied by MarkT on topic Wiring
Rectifier won't always stop bulbs from blowing... might need to add a regulator which your bike didn't come with.
08 Dec 2021 05:59
- TIGER500
Going to add rectifier
09 Dec 2021 12:57
- Pete-RT1
Replied by Pete-RT1 on topic Wiring
"Going to add rectifier"
The rectifier is there to convert AC to DC.
To prevent bulbs blowing you'll need to add a Regulator.
Here's the bulletin yamaha-enduros.com/index.php/service-bul...e-voltage-regulators
Yamaha CT3 (in bits)
09 Dec 2021 13:35
