RT3 Rectifier Mounting Location
- ndemmert
RT3 Rectifier Mounting Location was created by ndemmert
I need a little help. I'm trying to straighten out a 1973 RT3 that I recently purchased which I overpaid for because the seller was not up front in his listing. Where is the rectifier mounted on this bike? Thanks for your help.
19 Sep 2021 05:12
Replied by MarkT on topic RT3 Rectifier Mounting Location
Normally under gas tank
19 Sep 2021 05:22
- ndemmert
Replied by ndemmert on topic RT3 Rectifier Mounting Location
Just curious how it's supposed to mount. Was hoping someone might have picture.
19 Sep 2021 05:30
BTW,
There are probably dozens of pics in the forum. I did a quick search and came up with this post... the pics appear to be rotated 90 degrees CW so the right side is the top. Area is right by ignition coil.
yamaha-enduros.com/index.php/forums/1972...ing-out-bulbs#106573
Tip on asking questions... in this case posting your own picture and saying "does this look right" is probably the best way to ask?
19 Sep 2021 05:49
- Pete-RT1
Replied by Pete-RT1 on topic RT3 Rectifier Mounting Location
I think it's the same mounting position as the RT1
Yamaha CT3 (in bits)
19 Sep 2021 05:50
- Pete-RT1
Sorry Mark, just seen your reply you are probably right.
If it's not one it'll be the other
ndemmert,
from the UK
ndemmert,
19 Sep 2021 06:01
No need at all to be sorry Pete! Thank you for posting a great pic!
19 Sep 2021 07:10
Replied by Gr8uncleal on topic RT3 Rectifier Mounting Location
Both of you are right, sort of!
On my RT2 it is mounted as per Pete's RT1 photo, but on my DT3 it is mounted as per the photos in Mark's link.
That's probably another small detail change between the 1972 and 1973 models to note!
19 Sep 2021 08:01
- ndemmert
I couldn't do that because it was missing and I had know idea how it was mounted. Thanks though.
19 Sep 2021 11:50
- ndemmert
Interesting. My bike does not have a mounting hole in that location.
19 Sep 2021 12:02
