Can’t find top end kit…??
- Oldskool18
Can’t find top end kit…?? was created by Oldskool18
New member here! I have a 1972 DT2 250 I bought a couple years ago… I tore down the top end and the piston looks rough! I CANNOT find a top end piston, rings, gasket etc. kit anywhere for this 72. Any help would be greatly appreciated!
74 DT 360
74 DT 125
72 DT2 250
77 KE 250
85 XR 80
78 GL 1000
2004 CRF150
2000 Valkyrie
2005 DRZ 400
2007 Zx-10r
74 DT 125
72 DT2 250
77 KE 250
85 XR 80
78 GL 1000
2004 CRF150
2000 Valkyrie
2005 DRZ 400
2007 Zx-10r
11 Jul 2021 17:25
Replied by MarkT on topic Can’t find top end kit…??
Contact Enduronut or DEET.
11 Jul 2021 19:11
Replied by Gr8uncleal on topic Can’t find top end kit…??
+1 to Mark's suggestion.
Also check out the online parts manuals on Partzilla and CMSNL and then search fleabay for the items individually. The piston and rings part numbers for your model have changed for some reason, so replace the first three numbers of the part numbers shown with 311 and search under this as well.
Treat with great suspicion any listing that says it fits DT2/DT3 AND RT2/RT3 - it almost certainly won't.
If you can, see if any sizes and manufacturers' marks are shown in fleabay listing photos, to confirm that these are the sizes that you want - some parts are often in the wrong box nowadays.
11 Jul 2021 23:49
- shyted
Replied by shyted on topic Can’t find top end kit…??
Remember as well,DT3 bits fit as it's pretty much the same bike.
Also check the part numbers on CMSNL and Partzilla as Al suggested then check TY 250 bits as that's what's going in mine . Think their hard to find there, then try living in the UK ! It's easier to find Chicken lips !
12 Jul 2021 13:44
- Oldskool18
Replied by Oldskool18 on topic Can’t find top end kit…??
Thanks everyone for the replies, Enduronut located a piston and ring set for me so hopefully it will be up and running for mid- Ohio vintage days! I was hoping other years of the 250 would interchange parts so thank you for that!!
74 DT 360
74 DT 125
72 DT2 250
77 KE 250
85 XR 80
78 GL 1000
2004 CRF150
2000 Valkyrie
2005 DRZ 400
2007 Zx-10r
74 DT 125
72 DT2 250
77 KE 250
85 XR 80
78 GL 1000
2004 CRF150
2000 Valkyrie
2005 DRZ 400
2007 Zx-10r
12 Jul 2021 21:08
As you're in the US, both CMSNL and Partzilla will give good info on what other models shared a specific part (not as good for Brits, Europeans or Antipodeans!).
13 Jul 2021 01:36
- Bartman512
Replied by Bartman512 on topic Can’t find top end kit…??
Im on my 4th over bore on my DT2 and had to go with a Weisco piston and rings.
13 Jul 2021 06:36
Bartman512 - Curious if you contacted Enduronut or possibly DEET about a piston and rings? Using ebay or other sources your choices are definitely limited... and often very expensive.
Enduronut had a huge supply of pistons and rings at very good prices... OEM and aftermarket brands... but I suppose eventually he'll be getting low on some items.
13 Jul 2021 06:42
- formulaz1
Replied by formulaz1 on topic Can’t find top end kit…??
Check out speed and sport in Pennsylvania
13 Jul 2021 17:06
- Mothersbaugh
Replied by Mothersbaugh on topic Can’t find top end kit…??
MarkT: yes, check post #5; he says Enduronut fixed him up.
13 Jul 2021 18:15
