1971 CT1 Gorman Special "Brandy"
  • asco
  • asco's Avatar Topic Author
Replied by asco on topic 1971 CT1 Gorman Special "Brandy"
If anybody is curious my polishing process it is probably a little bit different than others. I start off with a wet dry 400 grit sandpaper and WD-40. Small amount of oil.
After that I wipe it dry and go over it with wet dry 1500 grit sandpaper and mother's aluminum polish. I just dip the corner of the sandpaper into the material and I go over it a second time.
Then, I normally I get out the polishing wheel of which I bought at Harbor Freight first using the black and then the white compound. After it's looking pretty good I will take my finger and I will dab just a little bit of mothers on the general working area and do a finish. Some of the hard-to-reach areas need to be done again and detailed out.
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
08 May 2018 17:30 #21
  • asco
Do not attempt to adjust your television set. The pictures are dark. A few days until the next update are expected.
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
11 May 2018 15:54 #22
  • asco
Took a week off of polishing. Today, I will finish the cases, clean the skid plate and get her back together this coming week. I have not ordered the fuel tank badges yet.
asco
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
Last edit: 19 May 2018 09:24 by asco.
19 May 2018 09:23 #23
  • asco
Brandy, is nearly all buttoned up. After the large side case tried to slip out of my hand I decided that - that was enough polishing. That was a corporate decision made instantaneously.
There were a few mechanical things that needed to be checked, double checked and fixed. Nothing a novice like myself cannot handle.
Now to start a yama-riot.
I'm going to be buying some oil.
What type should I buy? lol..
I will probably go to Van Nuys Suzuki.
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
Last edit: 19 May 2018 14:58 by asco.
19 May 2018 14:20 #24
  • asco
I will not know for sure until I get it out into the bright sunlight. Was not happy after two times of color sanding still had some low spots that needed to be removed. 800 grit - 1500 grit - 2000 grit rubbing compound again, polishing and several coats of wax. Now, I'm absolutely certain why these guys get so much money to paint these fuel tanks.
Oil in the crankcase. Missing a couple of very long Allen bolts in the 55 to 70 mm range. It looks really good. A tremendous amount of work but you got to do what you gotta do.
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
21 May 2018 17:24 #25
  • asco
This year;
January to June really came fast. January, I worked on the 125 Dorthea. Never even put fuel in or purchased a new battery.
Brandy, is now finished. I figure close to 40 hours total - 25 on the fuel tank alone. I ordered the tank badges from Australia, they will be here in 3 weeks, perhaps.
Monica, will be started up and put on the rack and I will change out the right side clutch cover that has been damaged by a rock. Pretty simple procedure. Should only take another 3 weeks - laugh out loud ...
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
24 May 2018 08:06 #26
  • asco
I could not be more pleased..
Started 2nd. kick..
Took the buffer to the fuel tank for final finish (brave yama-dude)..
Ready !
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: Enduronut, MarkT, Crazy Horse 124
Last edit: 24 May 2018 12:04 by asco.
24 May 2018 12:03 #27
Replied by RALPH on topic 1971 CT1 Gorman Special "Brandy"
Congrats. It will look great with the badges installed.
24 May 2018 17:29 #28
  • asco
The fuel tank badges from Australia really didn't take that long to get here. It said June 18 and arrived yesterday on the first.
The bike really looks good and I'm quite pleased.
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
The following user(s) Liked this Post: jims175, Badger52
02 Jun 2018 10:10 #29
  • asco
Upcoming for sale.
Note: shutting down both storage units and returning leased car. Save $1000.00 a month. It’s not a fire sale. This will be a nice bike. Good looking. Reliable.
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
25 Mar 2019 14:33 #30
