Starts after 23 years-but dies fast
- Sneezles61
Replied by Sneezles61 on topic Starts after 23 years-but dies fast
Guitar strings have helped me.
17 Nov 2024 05:14
#11
- Schu
Replied by Schu on topic Starts after 23 years-but dies fast
Also make sure your air filter is still good. The photo linked below shows an air cleaner that appeared to be ok until I tried to remove the foam from the cage for cleaning.
imgur.com/a/U6cOqXO
imgur.com/a/U6cOqXO
17 Nov 2024 07:31
#12
Replied by RT325 on topic Starts after 23 years-but dies fast
When the pilot jet is removed I use an acupuncture needle I bought home a few of haha. Works good on the little cross holes on the needle jet when removed also. When the pilot is in place I'd have no chance with anything flexible if blocked which is why I mentioned wire brush strand--just saying!!
17 Nov 2024 12:54
#13
- rpaldrich
Replied by rpaldrich on topic Starts after 23 years-but dies fast
Whoo hoo!
Got her running
.I followed ya'll's advice and took the carb all back apart and used a piece of wire brush wire to push and prod as much as I could. The pilot jet is definitely NOT gonna come out though. It was so torn up by previous attempts that all I did was round it off more....but I did get all of the pieces cleaned up / out, and blew out everything with air.
Started right up. I don't have any experience w/ 2-stroke bikes and have only ridden a 4 stroke a handful of times. Anybody notice any weird noises or anything? It is idling ~1700-2000rpm without choke, so seems fine, right?
To do (I'll make separate posts if needed):
--unfreeze clutch plates (Even with clutch pulled in I cannot disengage motor from tranny)
--replace clutch adjustment screw (frozen. Perhaps I'm not getting enough clutch engagement which is causing the above)
--fill gas tank with vinegar and flush out all the surface rust in interior
--fix kick-starter. I think it is missing a shim, but it is getting stuck at the bottom of the stroke. Not a big deal, but annoying
--do something with the front forks cause they are way too spongy.
--replace kick starter gear cause the teeth are somewhat chewed up
--replace/refit original tool kit
--get safety gear for riding
--Title/Register and ride
The following user(s) Liked this Post: pahiker, 2strokenewb
17 Nov 2024 15:16
#14
Replied by Ht1kid on topic Starts after 23 years-but dies fast
I would change out the front and rear brake shoes 50 yr old shoes can delaminate for safety reasons It’s happened to me before
The following user(s) Liked this Post: MarkT, Oldbikenut
17 Nov 2024 17:08
#15
Ya on a roll that's good. If ya in at the kick gear the clutch is easy to separate & clean up. Also dispose of the rubber separating rings that sit under each fiber. They serve no useful purpose & may already have been removed. Be careful assembling the kick assembly as has a bent ear friction clip thingy that needs its ear engaged in a slot in the inner case. Mind you I've forgotten what bike you have so any smaller up to 175. Clutch actuator on the left needs oil or grease to move freely.
17 Nov 2024 19:19
#16
- Reed valve Richards
Replied by Reed valve Richards on topic Starts after 23 years-but dies fast
Yo Joe, Go Joe
19 Nov 2024 00:41
#17
