Starts after 23 years-but dies fast
- rpaldrich
Starts after 23 years-but dies fast was created by rpaldrich
Hey!
first post, but I have a 1971 AT1. I can get it to start and it will run for about 5-8 seconds then shut off. So far it has only started w choke on, and it dies faster when I turn off the choke, and also hasn’t gotten warm enough to really tell if it’ll run w choke off. Increasing throttle kills it too.
runs on pump gas (and oil). So anyway, where should I start? I can buy a cheap $35 mikuni carb off amazon and see if that fixes it, but don’t want to chase parts either.
71AT1 video link . Also put as attachment to this post.
15 Nov 2024 16:48
- pahiker
Replied by pahiker on topic Starts after 23 years-but dies fast
Have you cleaned the carb, verified jets and float level?
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
2024 Suzuki DR650
The following user(s) Liked this Post: Schu, Oldbikenut
15 Nov 2024 17:17
Replied by Ht1kid on topic Starts after 23 years-but dies fast
Greetings from Tennessee
15 Nov 2024 18:00
- rpaldrich
Replied by rpaldrich on topic Starts after 23 years-but dies fast
I’ve cleaned the carb, yes. But one (maybe the only one) of the jets’ that was deep down had the slot all stripped up, and I couldn’t get it out. All other parts were removed and cleaned.
And blown out w air.
15 Nov 2024 18:05
Replied by MarkT on topic Starts after 23 years-but dies fast
It sounds like you are describing the pilot jet is stuck and that's the most likely culprit for the issue you're having.
I might have a good used original carb body cheap if you can't get the jet out and need to replace the body... aftermarket carb is generally not the way to go.
The following user(s) Liked this Post: Schu, Ht1kid, Oldbikenut
15 Nov 2024 19:03
- rpaldrich
Ok thanks. I guess I’ll pull it apart and see if I can get that jet out. I might take you up on that spare carb if I can’t get this working.
- on the carb there were two adjustment screws that are spring-loaded. The idle speed screw and the throttle screw. One of them is larger l, near the center driver side and can be adjusted by hand or slotted screwdriver. the other is smaller, near the driver right side and needs slotted driver to adjust. Any idea which is which? And how many turns out from bottomed? My manual doesn’t differentiate them but says idle 1 1/2 — 2 turns out for the idle screw.
Factory manual is available in Tech Library here.
Larger central screw is idle stop screw. No "turns" spec... you use it to set the idle speed.
Smaller screw towards rear is idle air and spec is generally 1.5 turns out from lightly seated.
15 Nov 2024 19:38
Replied by RT325 on topic Starts after 23 years-but dies fast
Leave the throttle shut with choke on & don't touch it until it settles down.
But that's on a good carb, not yours.
You could hand choke it over the carb mouth varying the hand as it improves & will accept throttle.
I'd say the pilot is blocked but seeing it won't come out without problems i'd pull a strand out of your wire brush & poke it right through & out into the venturi, that'd work except there's also an angled hole in the forward end coming off the pilot drilling, ya might get lucky then blow it through again. Also think i'd raise the slide needle "by lowering the clip".
But bottom line might be the main jet.
Its in the side mount on the bowl. Remove it from its holder & look behind it plus through it as everything 'except pilot & choke' comes through the main jet.
Also the choke "fixed jet" in the bowl cavity may need poking--look down with a light, it's small.
Re-thinking, wire brush might be too big for the pilot jet but just be careful. If all else fails then a new cheap Chinese carb will fix it. Uhh--did i say that. Here's mine lol.
The following user(s) Liked this Post: Schu, Reed valve Richards, 2strokenewb
- Reed valve Richards
Replied by Reed valve Richards on topic Starts after 23 years-but dies fast
Yo Joe, Go Joe
17 Nov 2024 01:17
Great pic there RVR, Expand up totally clear. Can see right in.
17 Nov 2024 02:31
