What finish should I use on polished aluminum???
  • noteforjim@gmail.com
  • noteforjim@gmail.com's Avatar Topic Author
What finish should I use on polished aluminum??? was created by noteforjim@gmail.com
Does anyone know what is the best finish to spray on the cases and forks etc. after they have been polished?
Any help would be appreciated
26 Oct 2023 09:49 #1
Replied by 1971DT250 on topic What finish should I use on polished aluminum???
I leave them bare.
26 Oct 2023 13:47 #2
You can apply any topping you choose however it will darken the brightness and will need to be removed anyway to do anything.
400 wet sandĀ
polish
re install on the bikeĀ
AsHo
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
26 Oct 2023 18:38 #3
ceramic wax
27 Oct 2023 00:52 #4
Replied by Bent Trigger on topic What finish should I use on polished aluminum???
More Polish!!
1966 Triumph Trophy TR6SR
1970 Husqvarna Sportsman 360
1971 Husqvarna Enduro C 360
1972 Husqvarna 450CR
1973 Husqvarna 250WR
1973 Husqvarna 360RT
1974 Husqvarna 450WR
1977 Amen Savior KZ1000 Chopper
1999 Kawasaki ZRX1100 150HP
A TON-O-Generators 1925-1965
28 Oct 2023 17:17 #5
I recall earlier postings recommending an aerosol product called Gibbs Penetrant to prevent oxidation
of polished aluminium .
28 Oct 2023 23:23 #6
The only product that I apply to a freshly polished item is Acetone. The acetone removes all the black polishing compound completely without dulling the surface.
AsHo
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
28 Oct 2023 23:36 #7
gibbslubricant.com/applications/
Sounds like it promises a lot.
Gonna need to try it.
29 Oct 2023 15:13 #8
Polished my aluminum on my 250A and left it bare. I ride back roads and stone chips are unavoidable. I have been using Gibbs Penetrant for a few years now. It helps alot but you will still want to polish with Mothers alum polish once in a while to brighten it back up.
1974 DT250A
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
"And there ya have it"
29 Oct 2023 17:26 #9
