will a 1971 ct1 cylinder fit on a 1970 ct1?
  • tblank9824
  • tblank9824's Avatar Topic Author
15 Apr 2023 09:51 #1
Yes
15 Apr 2023 10:00 #2
Replied by Gr8uncleal on topic will a 1971 ct1 cylinder fit on a 1970 ct1?
CMSNL list the same part for all CT1 models from 1969 to 1971, so I would say yes.
15 Apr 2023 10:02 #3
So will an AT1 if ya want to go slower. Be careful someone's not misidentifying a "71 & its a reed "72 as i think the old rod change trick comes into play.
15 Apr 2023 15:33 #4
  • tblank9824
Replied by tblank9824 on topic will a 1971 ct1 cylinder fit on a 1970 ct1?
Thanks for the info. Would a 1970ct1 Head work on a 1971 at1 cylinder?
15 Apr 2023 19:20 #5
Two answer. No--but yes. it fits but being 66mm instead of 56 it finishes way out past the 125 cylinder. 175 Gasket being 66 sits way out but i [think] there's enough flat area to seal on the 125. Not the best plan & low compression too, lower than low. Yep she'd run.
Last edit: 15 Apr 2023 20:05 by RT325.
15 Apr 2023 20:03 #6
