Frames
- Crazy Horse 124
Frames was created by Crazy Horse 124
Do the RT1 and the DT1 share the same frame? In other words will a 360 engine fit in my 250 frame?
01 Nov 2022 08:35
Replied by Gr8uncleal on topic Frames
CMSNL suggests that they are the same dimensions (see attached). However, wait for confirmation from other members.
FRAME COMP YAMAHA BLACK for DT1E 1971 USA - order at CMSNL
The following user(s) Liked this Post: Crazy Horse 124
01 Nov 2022 10:40
Replied by RT325 on topic Frames
Yes drops straight in. Think very first DT1 had top rear mounts further out but still in line with spacers each side to fill the gap. In fact my Boss went over from NZ to ride the Big Bear Run or one of those in the US & while he was away i took his RT1MX motor & fitted in my early DT1 just because i liked my bike the way i had it setup to race.
The following user(s) Liked this Post: AirborneSilva, Ht1kid, Crazy Horse 124
01 Nov 2022 14:27
- Crazy Horse 124
Replied by Crazy Horse 124 on topic Frames
Thanks for the great information.
01 Nov 2022 19:40
- YamJab
Replied by YamJab on topic Frames
Does this look super dangerous? I don’t take the bike on a track or abuse it. As you can see it’s right above the rear brake shaft/mount
03 Nov 2022 19:23
Replied by Ht1kid on topic Frames
Yes get it welded possibly losing control of your bike isn’t worth it. It’s only going to get worse
03 Nov 2022 20:41
Now you've got me guessing YamJab--& welcome. The suspense is killing me lol, what bike do you have. Cheers from NZ.
03 Nov 2022 20:57
- AirborneSilva
Replied by AirborneSilva on topic Frames
Whoever does the welding make sure they terminate the crack or it could keep traveling after the weld.
The following user(s) Liked this Post: MarkT, msavitt, Crazy Horse 124
04 Nov 2022 02:30
- Schu
Replied by Schu on topic Frames
I’ve never heard that before. Does terminate simply mean drill a small hole at the end of the crack?
04 Nov 2022 15:06
- AirborneSilva
SCHU yes it prevents the crack from continuing.
04 Nov 2022 15:29
