Fork measurement needed 71 CT1
- Dennis D
Fork measurement needed 71 CT1 was created by Dennis D
Could someone measure their CT fork tube from the bottom of the lower
tree to the centerline of the axle and let me know what you come up with?
I think the bike I am working on has had longer fork tubes installed on it.
Speedo cable and brake cable are short. Thanks, Dennis
01 Oct 2022 13:59
- Tom P
Replied by Tom P on topic Fork measurement needed 71 CT1
20.5"
01 Oct 2022 14:23
Replied by MarkT on topic Fork measurement needed 71 CT1
I'm not near a CT1 right now... but mod was DT forks on CT and Yamaha even listed parts needed for conversion in manuals.
I believe CT forks were 30mm OD upper fork tubes and DT was 34mm. So that would be a quick check too.
01 Oct 2022 14:32
Replied by Ht1kid on topic Fork measurement needed 71 CT1
My Ct1c is 19.5 in
01 Oct 2022 15:32
- Swoop56
Replied by Swoop56 on topic Fork measurement needed 71 CT1
Over the decades , these bikes can have had fork modifications .
Booster springs , different aftermarket fork springs , aftermarket damper rods , or shorter or longer
preload spacers . Any of these mods can affect the measurement you're looking for , let alone
sacking out of original fork springs , as did happen .
You've already had reported variations , albeit in the same ball park , but hopefully an average figure will emerge .
01 Oct 2022 16:34
Swoop yes my Ct1c was bought used a couple of years ago had a chamber and different carb had been rode hard but well maintained I rebuilt the forks and used KDI cables the best way is diameter as MarkT said mine is 30 mm
01 Oct 2022 17:04
- Dennis D
Replied by Dennis D on topic Fork measurement needed 71 CT1
These measure 21 3/4 from the bottom of the tree to the axle centerline.
30mm on the diameter. I had some cables from a 250 that worked out.
This also explains why the kickstand seemed so short on this bike. The longer
forks with the bigger tires really had it leaning over. Extending the kickstand
took care of that. Thanks for taking the time to get the measurements for me.
D
D
01 Oct 2022 20:33
- Dennis D
Agree on the measurement variations. I took this with the forks
fully extended. The clip on the lower tree for the cables was broken
also. Stock brake cable couldn't be routed behind the keyswitch
as it was in a bind. Tried moving the lever on the splines and
couldn't find a happy spot for adjustment.
01 Oct 2022 20:41
- Tom P
Just for the record, my measurement of 20.5" was with the forks fully extended, and I'm absolutely sure that this front fork is stock with no modifications.
01 Oct 2022 20:55
- Dennis D
I had a response of 20 1/4 from a guy with an original low mileage bike
so the responses are in the ball park. The longer forks work alright for
the guy that owns it, and he is tall so I wanted to keep them for him if
I could. Thanks again, D
01 Oct 2022 21:05
