CT1 175 wiring help!
  • JRunk31
  • JRunk31's Avatar Topic Author
CT1 175 wiring help! was created by JRunk31
Hello friends. I have a 1971 CT1-C 175. I’ve restored it over the last few years and it runs fine ‘but’ now I’ve decided to get the lights working.
New battery, new rectifier. New 6V led headlight on order (replaced the sealed unit). New led flasher relay (only for rear with 6V led strip) but herein lies my problem.
I believe the flasher relay attaches to the back of the battery box, but mine doesn't have one or any of the  wires left over to replace it. All of the flashers were removed when I got it (35 year garage find). Also the horn was removed.
I need help finding a good wiring diagram to see if the previous owner (deceased now) removed the wires from the harness to the original flasher relay location because they aren’t there anymore and I can’t imagine the original harness was wrapped in black electrical tape. However, the tail light wires (5) remain.
A lot of the wires in the headlight bucket have been unplugged also and not sure where they should connect to other than signal lights.
Please help with light wiring advice!
16 Sep 2022 23:04 #1
Replied by RT325 on topic CT1 175 wiring help!
Welcome from NZ. I shouldn't start guessing so don't take my comments as correct until someone confirms or puts me right--but, By memory there's should be a light brown DC in to power the relay then a light brown & white heading away from the relay to the flasher switch for left-right. The Dark brown for left flasher & dark green for the right. That'll get ya started. I worked on these when new where I worked. Im lucky if I can remember yesterday sometimes. But can remember 50 years ago better haha.
The following user(s) Liked this Post: Sneezles61, JRunk31
Last edit: 17 Sep 2022 00:17 by RT325.
16 Sep 2022 23:53 #2
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic CT1 175 wiring help!
Original flasher relay was mounted on the frame below the tank, more or less "underneath" the ignition coil - there should be a square lug, with a M6 thread in it. The Brown and brown/white wires should exit the main loom in this vicinity.
Dark brown wires for left side, dark green for right. In the headlight bucket, there should be triple female bullet connectors in these colours, and these take the males from the front flashers, left switch and warning light in the tacho.
The following user(s) Liked this Post: MarkT, RT325, Ht1kid, Pete-RT1, JRunk31
Last edit: 17 Sep 2022 00:23 by Gr8uncleal.
17 Sep 2022 00:21 #3
Replied by MarkT on topic CT1 175 wiring help!
Yes, brown and brown with white stripe under fuel tank is for flasher.  Many wiring diagrams in the Manuals in the Tech Library.  The early ones have legends for the colors and can be very helpful.  Yamaha kept wire color and use relationships the same for many years.
17 Sep 2022 06:08 #4
  • Quartermaster35
  • Quartermaster35's Avatar
Replied by Quartermaster35 on topic CT1 175 wiring help!
You can find a wiring diagram in the Tech Library in the service manual for your CT1.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
17 Sep 2022 15:44 #5
Replied by DEET on topic CT1 175 wiring help!
Your bike is a mixture of AC power and DC power.
The turn signals are DC and the flasher indicator in the tach won't work with unmodified LEDs.
Horn is DC.
Brake light is DC.
Headlight power is AC.
Instrument lights are AC
Depending on the year, the tail running light is AC.
If you don't understand the difference between AC and DC voltage (and how it will affect your bike) Google them for an explanation.
The following user(s) Liked this Post: Ht1kid, Sneezles61, JRunk31
17 Sep 2022 19:39 #6
Replied by Pete-RT1 on topic CT1 175 wiring help!
Here's how on my CT1-C I replaced my standard bulbs with LED, it might help.
Good luck with it.
www.yamaha-enduros.com/index.php/forums/...14993-led-indicators
Yamaha CT3 (in bits)
18 Sep 2022 03:14 #7
Replied by Ht1kid on topic CT1 175 wiring help!
CHP Honda has a LED indicator bulb that is a direct replacement with no modifications works great on my CT1c
18 Sep 2022 07:34 #8
Led Bulb for the tach (clock) it does blink with your turn signals also can use for your instrument lights
18 Sep 2022 09:24 #9
  • JRunk31
Replied by JRunk31 on topic CT1 175 wiring help!
I found “the” diagram in the very last page of the original CT1 manual.
 Yes, the brown/white wire and brown (common) wire go into flasher relay (under the tank right  by the pink and brown (common) wire for the horn)! I find it odd that there are two sets of two of these brown commons here.
I went with an LED flasher relay only to power my rear LED brake/tail/signal light. At the rear I have a light green and light brown signal wires instead of dark green and brown and I guess this was somewhat of a norm.
i will connect the male / female bullet connectors in the headlight bucket and give it a go. Please see pics and let me know of those connect? Please and thanks!
Also, what’s the green w/ yellow stripe wire in the headlight bucket for? He’s the only one without a mate. And why are there two reds wires at the taillight bunch? One is hot 6.52V the other cold, both red. See pics.
23 Sep 2022 14:42 #10
