wiring question on a 71 DT250
- 5gear
wiring question on a 71 DT250 was created by 5gear
i bought this bike a week and a half ago and i've been trying to put the lights and wiring back together after the previous owner took them off. i believe i have connected the battery+ to the red wire that runs to the rectifier, but there is another red wire in that area by the oil tank, and it has a male and female end.
can someone tell me what they do / where they go?
21 Jul 2022 18:27
Replied by MarkT on topic wiring question on a 71 DT250
Three reds. Two go to factory fuse holder. Third to battery. Probably a few dozen threads with pictures on this topic if you search.
21 Jul 2022 19:18
Someone will correct me if I'm wrong but pretty sure two harness females connect to fuse holder and male harness to battery.
21 Jul 2022 19:20
Replied by Ht1kid on topic wiring question on a 71 DT250
Yes 2 females to fuse holder that’s what I did
21 Jul 2022 21:31
How I remember it without looking at the parts is Yamaha engineered those connections very well...
Battery + has a female that protects it from a short to ground
Harness wire that goes to battery has the male... if it was disconnected from battery and shorted with engine running the power from stator to battery is protected by fuse...
Same with all the other connections... either protected from short to ground by being a female connector or protected by fuse if not.
22 Jul 2022 04:07
- 5gear
Replied by 5gear on topic wiring question on a 71 DT250
Thanks to all of you, and in my defense, i did search for this, (i'm sure they're there) but i did not find what i was looking for.
22 Jul 2022 05:28
- AirborneSilva
Replied by AirborneSilva on topic wiring question on a 71 DT250
Search is hit and miss, if you don't use the right wording you can get threads that have little to do with what you're looking to find...
22 Jul 2022 07:16
Replied by Gr8uncleal on topic wiring question on a 71 DT250
"Search is hit and miss, if you don't use the right wording you can get threads that have little to do with what you're looking to find..."
If I remember correctly (not guaranteed!
), the "Search Forum" button on the lower toolbar is more effective that the "Search" button on the top toolbar.
The following user(s) Liked this Post: Ht1kid, 5gear
22 Jul 2022 07:53
- AirborneSilva
Hi Alan, I never paid any attention to the search at the bottom. I'll have to give that a try next time I do a search.
22 Jul 2022 08:42
Yes, DEFINITELY make sure you select search forum! Not just search.
22 Jul 2022 20:12
