1969 ct1 Blowing fuse .
  • RLC158
  • RLC158's Avatar Topic Author
1969 ct1 Blowing fuse . was created by RLC158
Hope somene can help.My CT1 keeps blowing the 10amp fuse.by a process of elimination i found that if i disconnected the red and white from the stator it would not blow as soon as i connected iit into the loom and switched ignition on it blows.have checked loom for short but cannot find any.
Regards Glyn
04 May 2022 04:06 #1
Replied by RT325 on topic 1969 ct1 Blowing fuse .
I don't recall a red & white wire from the stator. Did you mean two wires "red" & a "white" or one red/white striped wire. Nearest i can think would be "Green/Red" from stator. Anyway, my first thought going by what you say 'is' that the rectifier under the tank is shot. Rectifier has a white wire going in from the loom & a red wire going out to the battery via the loom. If it's poohed it can short the battery back down to the lighting coil. Not even sure that would blow the fuse or if it would just drag the life out of the battery very fast as wouldn't be a dead short but a high resistance i guess [help somebody please] out of my depth without being there to prod & poke haha--lot easier when you see smoke [Ahha, there's the problem].
Last edit: 04 May 2022 05:29 by RT325.
04 May 2022 04:42 #2
Replied by Gr8uncleal on topic 1969 ct1 Blowing fuse .
Red and white is from the lighting coil?
Have a look in the generator area to see if anything is shorting out there.
04 May 2022 05:28 #3
sorry trying to find a CT1 wiring pic in color but makes sense now what GR8Uncleal says.
04 May 2022 05:42 #4
Is it just me?--but can't see a red white from the lighting coil. Think its green then green/red then yellow.
Link to a "71 CT1 from the tech library. Expands up really clearly. Goodnight.
yamaha-enduros.com/index.php/wiring-diag...ing-diagram/download
Last edit: 04 May 2022 06:01 by RT325.
04 May 2022 05:59 #5
I was looking at the picture of a new lighting coil on CMSNL for the 1971 CT1C.
04 May 2022 06:25 #6
Replied by MarkT on topic 1969 ct1 Blowing fuse .
Sounds like bad rectifier?
The following user(s) Liked this Post: LETSJET, asco, Pedalcrazy
04 May 2022 11:08 #7
