1971 CT1 Front and Rear End Components Compatablity with a '73 DT1F 250
- mx360guy
1971 CT1 Front and Rear End Components Compatablity with a '73 DT1F 250 was created by mx360guy
Hi all,
I have an opportunity to purchase a rusty but complete '71 CT1 175. I have a '73 DT1F 250 that has good front, rear, and decent wheels.
Would the complete front end and rear end of the DT fit on the CT1?
15 Apr 2022 08:17
- Sneezles61
Replied by Sneezles61 on topic 1971 CT1 Front and Rear End Components Compatablity with a '73 DT1F 250
What I've been doing to see IF parts will swap, is to go to a partszilla look up the bike you intend to re-build.. look at the part and write down the part number... THEN.. go look at the donor bike on partszilla and look at the part that you want to swap.. Obviously, the first numbers refer to which bike is which, but then the next set of numbers will help you determine IF they are compatible... It takes some time.. but I have to believe, many others have done this... Call it... Education... It helps me answer my questions.. for the most part..
Sneezles61
EDIT: yer moniker makes me smile!!
Sneezles61
- Swoop56
Replied by Swoop56 on topic 1971 CT1 Front and Rear End Components Compatablity with a '73 DT1F 250
Sorry to be a wet blanket , but Sneezles information is incorrect .
He is right in that the prefix of the part number identifies the bike ,
but the second section only identifies the type of part , and does in no way
signify compatability .
An example would be a std piston for a DT 250 and a DT 360 .
The prefix number is the only difference in the part number ,
but physically the 360 is 10mm larger diameter .
As for your original question . I believe that fitting the entire 250 front end ,
triple clamps included , has been successfully done before .
15 Apr 2022 15:38
Replied by MarkT on topic 1971 CT1 Front and Rear End Components Compatablity with a '73 DT1F 250
Front, yes
Rear, no
Rear, no
15 Apr 2022 18:00
Replied by RT325 on topic 1971 CT1 Front and Rear End Components Compatablity with a '73 DT1F 250
Short answer 'No'. Shortest answer i've ever given lol. Swoop are ya watching nz superbikes today--tomorrow.
www.ctaslive.nz/wsNZGP.aspx?z=&t=12:16%20Superbike(R1)-f
- Swoop56
Morley . Normally I'd be there as part of the officials crew . Not asked this year .
Thanks for the link . I'm not the best at the technical stuff , but hopefully I can tap into it , to watch .
15 Apr 2022 18:23
Yep pretty easy to navigate with video bottom right, chat room on left & lap timing there somewhere. One of my boys mans a camera for Ctas & flew down yesterday. I forgot it was on until just now & see Tony Rees finish second if was looking back correctly. Go that man.
