DT1 Clutch Push Rod Ball
- DTDouglas
DT1 Clutch Push Rod Ball was created by DTDouglas
Hi Guys, Bought a non-running 1971 DT250. Clutch lever didn't move so I cleaned up the actuator, or worm gear, and found a bent push rod. Replaced the rod with one the same length and found I could not reach it with the adjustment screw. I put a second ball in, and that worked out, so clutch lever working now. I don't see a second ball in the parts diagrams but the photo of the 1971 Service Manual does show a second ball. Is a second ball correct, or do I have another problem?Thanks, Doug
The following user(s) Liked this Post: bart.ives, adguy2112
- 1971DT250
Replied by 1971DT250 on topic DT1 Clutch Push Rod Ball
There is a ball that is held captive in the actuator. There is another ball inside the clutch. This one is often left out by mistake after a rebuild or repair.
Replied by RT325 on topic DT1 Clutch Push Rod Ball
As said above--there's one in the actuator [& its lightly riveted in] but does escape sometimes when ya not looking when its apart. Trouble with adding a ball 'is' you'll be running a 1/4 ball in the pushrod tunnel against a 5/16 ball down the other end at the mushroom which can't be good. A 1/4x1/4 roller like my old bsa big end had would be better.
16 Dec 2021 13:04
- DTDouglas
Replied by DTDouglas on topic DT1 Clutch Push Rod Ball
Thanks, Took the cover off again and looks like the ball in the actuator is gone.
18 Dec 2021 05:55
